I've seen that's there's a popup before the playback starts within the "Apple Trailers" plugin. I think that this is automatically created by Plex.
But is there any chance to realize it by myself? So I can choose which quality will be streamed from a live-source...
I've attached a screenshot to show which popup I mean...
Greets
Sascha
That popup is generated when you include more than one MediaObject in the MediaObjectsForURL() function of the URL Service. Most Plex client apps (generally the mobile ones) skip the popup and make an "intelligent" selection based on user settings, wifi vs 3/4G, local vs remote, etc. PHT (and I believe Plex/Web) have settings to auto-select from the list and skip the popup as well.
If you're not using an URL Service, it will be a little more complicated but should still be do-able. The main idea is to return a list of MediaObjects each with a different resolution from the method that is constructing the VideoClipObject. I can't think of any examples where this is done without an URL Service but if you look in the Services.bundle, there are lots of examples that use it there.
Damn :-)
Do I always have so strange requirements or why I'm continously faced with undocumented individual solutions :-)
You were right. Just adding MediaObjects with different resolutions will show this popup...
It’s not just you
Just that (unfortunately) the documentation is lacking.
