Under the various IP settings, does PMS support CIDR notation, or does it require netmask formatting for those fields?
For example, on the Network tab, you have ‘LAN Networks’ and the ‘List of IP addresses and networks that are allowed without auth’ fields, if I want to put the class C in there, can I put in 192.168.1.0/24, or does it have to be 192.168.1.0/255.255.255.0? If it does, you really should update the documentation, both in your support documents, as well as the description areas below the fields in the configuration pages.
