Every so often I have a failed recording with the error message
There was a transcoder error
Here are the pertinent (I hope) logs from the last failure this morning
One comment is the warning line with PARSUB is repeated many, many times (I only posted a few) with the only difference being the time and the bit in bold italics (what was received). I am not sure if this is relevant or not).
Thanks for you help!
James.
Jul 22, 2018 04:33:00.717 [0x7f6b2f2f9700] ERROR - Unable to find title for item of type 5
Jul 22, 2018 04:33:00.718 [0x7f6b2f2f9700] ERROR - Unable to find title for item of type 5
Jul 22, 2018 04:33:06.664 [0x7f6b1fb7d700] ERROR - [Transcoder] http://192.168.1.240:5004/auto/v39: Server returned 5XX Server Error reply
Jul 22, 2018 04:33:30.741 [0x7f6b2f2f9700] ERROR - DVR:Recorder: No part because session isn't reporting one.
Jul 22, 2018 04:33:30.741 [0x7f6b2f2f9700] ERROR - DVR:Recorder: Couldn't obtain a part, something went wrong.
Jul 22, 2018 04:33:30.741 [0x7f6b2f2f9700] ERROR - DVR:Recorder: Error 12 (There was a transcoder error) starting the record, shutting things down.
Jul 22, 2018 04:33:30.782 [0x7f6b2f2f9700] ERROR - DVR:Grabber: Starting media grab failed.
Jul 22, 2018 05:02:45.398 [0x7f6b313ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (40900cb5-6576-476f-bf6f-ceaeaa3bbe5d, expected 3321848a-967f-4792-ab79-06ecaa691a52)
Jul 22, 2018 05:03:06.901 [0x7f6b1cfff700] ERROR - downloadContainer: expected MediaContainer element, found html
Jul 22, 2018 05:03:06.901 [0x7f6b1cfff700] WARN - DVR:Subscription: No container available for /tv.plex.providers.epg.onconnect:4/metadata/com%2Egracenote%2Eonconnect%3A%2F%2Fshow%2F12900236
Jul 22, 2018 05:03:07.898 [0x7f6b1ea23700] ERROR - Unable to find title for item of type 5
Jul 22, 2018 05:03:13.005 [0x7f6b27bff700] ERROR - [Transcoder] http://192.168.1.240:5004/auto/v39: Server returned 5XX Server Error reply
Jul 22, 2018 05:03:13.133 [0x7f6b25fff700] ERROR - downloadContainer: expected MediaContainer element, found html
Jul 22, 2018 05:03:13.133 [0x7f6b25fff700] WARN - DVR:Subscription: No container available for /tv.plex.providers.epg.onconnect:4/metadata/com%2Egracenote%2Eonconnect%3A%2F%2Fshow%2F12900236
Jul 22, 2018 05:03:21.163 [0x7f6b1cfff700] ERROR - downloadContainer: expected MediaContainer element, found html
Jul 22, 2018 05:03:21.163 [0x7f6b1cfff700] WARN - DVR:Subscription: No container available for /tv.plex.providers.epg.onconnect:4/metadata/com%2Egracenote%2Eonconnect%3A%2F%2Fshow%2F12900236
Jul 22, 2018 05:03:26.584 [0x7f6b25fff700] ERROR - downloadContainer: expected MediaContainer element, found html
Jul 22, 2018 05:03:26.584 [0x7f6b25fff700] WARN - DVR:Subscription: No container available for /tv.plex.providers.epg.onconnect:4/metadata/com%2Egracenote%2Eonconnect%3A%2F%2Fshow%2F12900236
Jul 22, 2018 05:03:28.146 [0x7f6b25fff700] ERROR - downloadContainer: expected MediaContainer element, found html
Jul 22, 2018 05:03:28.146 [0x7f6b25fff700] WARN - DVR:Subscription: No container available for /tv.plex.providers.epg.onconnect:4/metadata/com%2Egracenote%2Eonconnect%3A%2F%2Fshow%2F12900236
Jul 22, 2018 05:03:37.911 [0x7f6b1ea23700] ERROR - DVR:Recorder: No part because session isn't reporting one.
Jul 22, 2018 05:03:37.911 [0x7f6b1ea23700] ERROR - DVR:Recorder: Couldn't obtain a part, something went wrong.
Jul 22, 2018 05:03:37.911 [0x7f6b1ea23700] ERROR - DVR:Recorder: Error 12 (There was a transcoder error) starting the record, shutting things down.
Jul 22, 2018 05:03:37.930 [0x7f6b1ea23700] ERROR - DVR:Grabber: Starting media grab failed.
Jul 22, 2018 05:03:43.017 [0x7f6b1efff700] ERROR - downloadContainer: expected MediaContainer element, found html
Jul 22, 2018 05:03:43.017 [0x7f6b1efff700] WARN - DVR:Subscription: No container available for /tv.plex.providers.epg.onconnect:4/metadata/com%2Egracenote%2Eonconnect%3A%2F%2Fshow%2F12900236
Jul 22, 2018 05:03:44.204 [0x7f6b2f2f9700] ERROR - Unable to find title for item of type 5
Jul 22, 2018 05:03:44.206 [0x7f6b2f2f9700] ERROR - Unable to find title for item of type 5
Jul 22, 2018 05:03:44.628 [0x7f6b313ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (f1ef2b7f-5193-42f9-ab92-1d396e29f941, expected 3321848a-967f-4792-ab79-06ecaa691a52)
Jul 22, 2018 05:03:45.000 [0x7f6b1cfff700] ERROR - downloadContainer: expected MediaContainer element, found html
Jul 22, 2018 05:03:45.000 [0x7f6b1cfff700] WARN - DVR:Subscription: No container available for /tv.plex.providers.epg.onconnect:4/metadata/com%2Egracenote%2Eonconnect%3A%2F%2Fshow%2F12900236
Jul 22, 2018 05:03:47.908 [0x7f6b25fff700] ERROR - downloadContainer: expected MediaContainer element, found html
Jul 22, 2018 05:03:47.908 [0x7f6b25fff700] WARN - DVR:Subscription: No container available for /tv.plex.providers.epg.onconnect:4/metadata/com%2Egracenote%2Eonconnect%3A%2F%2Fshow%2F12900236
Jul 22, 2018 05:03:49.354 [0x7f6b1e735700] ERROR - [Transcoder] http://192.168.1.240:5004/auto/v39: Server returned 5XX Server Error reply
Jul 22, 2018 05:03:49.796 [0x7f6b25fff700] ERROR - downloadContainer: expected MediaContainer element, found html
Jul 22, 2018 05:03:49.796 [0x7f6b25fff700] WARN - DVR:Subscription: No container available for /tv.plex.providers.epg.onconnect:4/metadata/com%2Egracenote%2Eonconnect%3A%2F%2Fshow%2F12900236
Jul 22, 2018 05:04:14.246 [0x7f6b2f2f9700] ERROR - DVR:Recorder: No part because session isn't reporting one.
Jul 22, 2018 05:04:14.246 [0x7f6b2f2f9700] ERROR - DVR:Recorder: Couldn't obtain a part, something went wrong.
Jul 22, 2018 05:04:14.246 [0x7f6b2f2f9700] ERROR - DVR:Recorder: Error 12 (There was a transcoder error) starting the record, shutting things down.
Jul 22, 2018 05:04:14.272 [0x7f6b2f2f9700] ERROR - DVR:Grabber: Starting media grab failed.
Jul 22, 2018 05:04:44.741 [0x7f6b31111700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (03282e39-5ab1-443d-9ccb-f71a128c8a4f, expected 3321848a-967f-4792-ab79-06ecaa691a52)
Jul 22, 2018 05:43:44.636 [0x7f6b31111700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (5f0ed0ff-3af2-4a63-9011-a661e9e530e3, expected 3321848a-967f-4792-ab79-06ecaa691a52)
Jul 22, 2018 05:44:37.312 [0x7f6b25a23700] ERROR - Error parsing XML.
Jul 22, 2018 05:44:37.488 [0x7f6b25fff700] ERROR - SQLITE3:0x10, 262, statement aborts at 15: [DELETE FROM gnsdk_queries WHERE "rowid"=15241;] database table is locked: gnsdk_queries
Jul 22, 2018 05:44:38.044 [0x7f6b25fff700] ERROR - SQLITE3:0x10, 262, statement aborts at 18: [SELECT rowid,* FROM gnsdk_queries WHERE "key" = ?;] database table is locked: gnsdk_queries
Jul 22, 2018 05:44:38.048 [0x7f6b25fff700] ERROR - SQLITE3:0x10, 262, statement aborts at 18: [SELECT rowid,* FROM gnsdk_queries WHERE "key" = ?;] database table is locked: gnsdk_queries
Jul 22, 2018 05:44:44.712 [0x7f6b31111700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (26b2e92b-92f3-42f6-b3ba-38fd55d32307, expected 3321848a-967f-4792-ab79-06ecaa691a52)
Jul 22, 2018 05:48:44.734 [0x7f6b31111700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (dc3d30a8-78ba-4cf1-b67b-f77174d185f7, expected 3321848a-967f-4792-ab79-06ecaa691a52)
Jul 22, 2018 05:48:51.934 [0x7f6b25fff700] ERROR - SQLITE3:0x10, 262, statement aborts at 15: [DELETE FROM gnsdk_queries WHERE "rowid"=15418;] database table is locked: gnsdk_queries
Jul 22, 2018 05:48:52.456 [0x7f6b27bff700] ERROR - SQLITE3:0x10, 262, statement aborts at 24: [INSERT OR REPLACE INTO gnsdk_queries ("key","value","timestamp") VALUES(?,?,?);] database table is locked
Jul 22, 2018 05:48:52.462 [0x7f6b25fff700] ERROR - SQLITE3:0x10, 262, statement aborts at 18: [SELECT rowid,* FROM gnsdk_queries WHERE "key" = ?;] database table is locked: gnsdk_queries
Jul 22, 2018 05:49:39.342 [0x7f6b25fff700] ERROR - SQLITE3:0x10, 262, statement aborts at 24: [INSERT OR REPLACE INTO gnsdk_queries ("key","value","timestamp") VALUES(?,?,?);] database table is locked
Jul 22, 2018 05:49:44.883 [0x7f6b2f2f9700] WARN - Held transaction for too long (../Sync/SyncItemGenerator.cpp:142): 0.120000 seconds
Jul 22, 2018 05:49:44.888 [0x7f6b31111700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (d9ef0cd0-10af-4d34-abcc-afa84340b475, expected 3321848a-967f-4792-ab79-06ecaa691a52)
Jul 22, 2018 05:49:44.888 [0x7f6b313ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (d9ef0cd0-10af-4d34-abcc-afa84340b475, expected 3321848a-967f-4792-ab79-06ecaa691a52)
Jul 22, 2018 05:49:59.933 [0x7f6b28847700] ERROR - SQLITE3:0x10, 262, statement aborts at 24: [INSERT OR REPLACE INTO gnsdk_queries ("key","value","timestamp") VALUES(?,?,?);] database table is locked
Jul 22, 2018 05:49:59.936 [0x7f6b29d11700] ERROR - SQLITE3:0x10, 262, statement aborts at 18: [SELECT rowid,* FROM gnsdk_queries WHERE "key" = ?;] database table is locked: gnsdk_queries
Jul 22, 2018 05:50:44.627 [0x7f6b31111700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (10fb06fe-de30-4a28-98db-03aafeabdd34, expected 3321848a-967f-4792-ab79-06ecaa691a52)
Jul 22, 2018 05:50:44.630 [0x7f6b313ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (10fb06fe-de30-4a28-98db-03aafeabdd34, expected 3321848a-967f-4792-ab79-06ecaa691a52)
Jul 22, 2018 05:51:44.619 [0x7f6b31111700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (3640a790-c7f6-4d8a-8235-3a84181c21e3, expected 3321848a-967f-4792-ab79-06ecaa691a52)
Jul 22, 2018 05:51:44.619 [0x7f6b313ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (3640a790-c7f6-4d8a-8235-3a84181c21e3, expected 3321848a-967f-4792-ab79-06ecaa691a52)
Jul 22, 2018 05:51:47.906 [0x7f6b29d11700] ERROR - SQLITE3:0x10, 262, statement aborts at 18: [SELECT rowid,* FROM gnsdk_queries WHERE "key" = ?;] database table is locked: gnsdk_queries
Jul 22, 2018 05:52:44.613 [0x7f6b31111700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (873b65be-4826-4dda-9698-fb4f03c418ec, expected 3321848a-967f-4792-ab79-06ecaa691a52)
