I have a new plex setup connected to an HDHomeRun Prime.
I have found that I am not able to record anything from NBC, but all other shows are recording just fine.
I am able to watch LIVE TV for that channel, but can’t record it.
I am able to record all other channels.
When I do record it, it fails (after a couple of minutes) with the error “There was a transcoder error”
I’ve checked the server and no file ever gets created in the “.grab” directory. It will create a subdir for the session, but no video file is created.
I’ve checked the HDHomeRun Prime, and it is being tuned to the proper channel
The HDHomeRun Prime even offered 2 channels for NBC (regular and HD).
I unselected the regular channel and tried to record the HD channel and had the same result.
Also, I am not transcoding on the fly.
I have attached the relevant logs
Any ideas?
Logs please and indication of time of error when uploading logs
See
https://support.plex.tv/hc/en-us/articles/201643703-Reporting-issues-with-Plex-Media-Server
https://support.plex.tv/hc/en-us/articles/200250417-Plex-Media-Server-Log-Files
If you have used the email interface for posting -that loses attachments
Use the forums directly through the web browser to attach files
Here are the logs (sorry, it posted twice, not sure why and only 1 had logs)
This is not a complete log file - can’t even tell what version you are running
Please always include full logs - preferably the zipped logs produced by the download logs interface
sorry, i had Verbose on for a bit, so I tried to only include the relevant parts
Here are the full logs
The error has been referred to the development team and will let you know when I have feedback
Oct 04, 2017 09:58:49.985 [6216] ERROR - [Transcoder] Stream map '0:3' matches no streams.
To ignore this, add a trailing '?' to the map.
Oct 04, 2017 09:58:50.001 [5616] DEBUG - Jobs: 'C:\Program Files (x86)\Plex\Plex Media Server\PlexTranscoder.exe' exit code for process 7284 is 1
Oct 04, 2017 09:59:18.979 [5616] DEBUG - Jobs: 'C:\Program Files (x86)\Plex\Plex Media Server\PlexTranscoder.exe' exit code for process 7284 is 1
Oct 04, 2017 09:59:18.979 [11180] DEBUG - DVR:Recorder: It took 30.9 sec to start the session for http://192.168.1.131:5004/auto/v1203
Oct 04, 2017 09:59:18.979 [4192] DEBUG - Jobs: 'C:\Program Files (x86)\Plex\Plex Media Server\PlexTranscoder.exe' exit code for process 7284 is 1
Oct 04, 2017 09:59:18.979 [8608] INFO - Notification: Recording Megyn Kelly Today - Episode 10-04 -
Oct 04, 2017 09:59:18.979 [4192] DEBUG - DVR:Recorder: Asked to stop recording 'Megyn Kelly Today - Episode 10-04'.
Oct 04, 2017 09:59:18.979 [4192] DEBUG - DVR:Recorder: Stopping transcode session.
Oct 04, 2017 09:59:18.979 [4192] DEBUG - Killing job.
Oct 04, 2017 09:59:18.979 [4192] DEBUG - Job was already killed, not killing again.
Oct 04, 2017 09:59:18.979 [4192] DEBUG - Stopping transcode session 5c8f9997-880d-4924-abf1-85d50dbe204f
Oct 04, 2017 09:59:18.979 [4192] DEBUG - Cleaning directory for session 5c8f9997-880d-4924-abf1-85d50dbe204f (C:\Users\reg05\AppData\Local\Plex Media Server\Cache\Transcode\Sessions\plex-transcode-5c8f9997-880d-4924-abf1-85d50dbe204f)
Oct 04, 2017 09:59:18.979 [5616] DEBUG - Jobs: 'C:\Program Files (x86)\Plex\Plex Media Server\PlexTranscoder.exe' exit code for process 10952 is -1059143458
i have been fighting similar errors for the past two weeks… but it only happens when recording Dr Phil.
I setup a second plex dvr server with a separate hd home run device to troubleshoot this and sure enough the 4pm showing of dr phil failed on both servers with failure to transcode 3 days in a row I end up with a 4 to 18 minute files.
@baileyjs78 could you please see if the problem is still there with Plex Media Server Beta release 1.9.5 - available from https://plex.tv/downloads
If it is, please let me have fresh logs of the issue.
Not a similar error
The failure was because the tuner returned a 5xx response - could have been 502 or 503 etc - not sure which
Oct 16, 2017 15:57:07.455 [0x700005e1d000] ERROR - [Transcoder] http://192.168.50.116:5004/auto/v5.1?transcode=mobile: Server returned 5XX Server Error reply
You can consult the manual / support info for the tuner to see what errors in the 500 range mean -
This was the recording that the error related to
Oct 16, 2017 15:57:02.045 [0x7000050cf000] DEBUG - DVR:Grabber: Starting operation for 'Dr. Phil - E25 - Our 21-Year-Old Daughter Is Gorgeous, Wild and Violent'.
Oct 16, 2017 15:57:02.052 [0x7000050cf000] DEBUG - Activity: registered new activity 596f8abe-e41a-4389-bb04-f3a5a62000d5 - Recording
Oct 16, 2017 15:57:02.053 [0x7000050cf000] DEBUG - DVR:Grabber: HDHomerun starting a media grab on device device://tv.plex.grabbers.hdhomerun/1054010C (Silicondust HDHomeRun EXTEND, supported) tuner 0.
You can see if that error is occurring each time
This is no longer happening after the update
my PMS automatically updated to 1.9.6.4385 yesterday and now this same thing is happening to me. transcoder error whenever i try to record TV. if I just play TV it’ll play sound but with black screen. the ‘now playing’ screen shows it transcoding audio, but doesn’t even list video. its not direct playing or transcoding. the tuner otherwise works fine in other programs. any help would be much appreciated
EDIT: i fixed it by uninstalling the server and re-installed 1.9.5.4339 and it is now working. that’s not exactly a fix, but it’ll do for now i suppose.
@devogod said:
my PMS automatically updated to 1.9.6.4385 yesterday and now this same thing is happening to me. transcoder error whenever i try to record TV. if I just play TV it’ll play sound but with black screen. the ‘now playing’ screen shows it transcoding audio, but doesn’t even list video. its not direct playing or transcoding. the tuner otherwise works fine in other programs. any help would be much appreciatedEDIT: i fixed it by uninstalling the server and re-installed 1.9.5.4339 and it is now working. that’s not exactly a fix, but it’ll do for now i suppose.
If there is a problem that is in 1.9.6 and not in 1.9.5 please raise a new forum topic with logs for the time of the issue
You have actually posted in a thread for an old problem that was fixed in 1.9.5.
The error could arise due to different causes and each needs to be investigated.
This is the exact thing that is happening to me as well. I could not find a link for 1.9.5 though to verify. If I run the HD HomeRun app, TV and audio work find. Nothing works via Plex.
I was able to locate a copy of 1.9.5 and I can confirm that everything now works correctly.
1.9.6.4401 beta Plex Pass release has just been made available
Please download from https://plex.tv/downloads
If there is still a problem, please provide logs and if possible a short clip from the video that also gives rise to the error
See
I can confirm that 1.9.6.4401 seems to be working. Only had it record 2 shows, but putting it through the paces now with multiple movies and shows recording all night.
Thank you for looking into this so quickly.
Recorded about 20 tv shows and 5 movies and not one failed recording.
Thanks for the feedback
here its still a issue with that error (There was a transcoder error)
i tryed for example an manual record and also receive that error (not only scheduled ones)
Nov 05, 2017 09:20:46.007 [0x150198bff700] DEBUG - DVR:Grabber: Operation for blablabalbla completed with status error (There was a transcoder error)
when i manually start LiveTV in browser it worked, then i started again a record and it worked …
any chance to raise “try” values … so a record wont get lost by 1 try and fail …
