Raspberry Pi not able to setup
So i have followed all of the steps i used previously to setup my Raspberry Pi 3+ for PLEX. It still doesn’t work and i am not sure what to do next. I am not a programmer and have very little knowledge of how to program these things and rely on your help. I ran my media off of it up until last week when an update sent everything haywire. I decided to start over. What info do you need to help me finish this setup?
If you still experience problems tell us more about your specific problem. What does not work? :wink:
So when I run a status check, it says the server is working. When I attempt to claim the server, putting in my ip address:32400/web/ states that it is unreachable.
Please post the output of systemctl status plexmediaserver.
pi@raspberrypi:~ $ systemctl status plexmediaserver
● plexmediaserver.service - Plex Media Server for Linux
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor
Active: active (running) since Mon 2018-09-03 16:28:23 EDT; 15h ago
Process: 8732 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_AP
Main PID: 8736 (sh)
CGroup: /system.slice/plexmediaserver.service
├─8736 /bin/sh -c LD_LIBRARY_PATH=/usr/lib/plexmediaserver "/usr/lib/
└─8740 /usr/lib/plexmediaserver/Plex Media Server
Sep 03 16:28:23 raspberrypi systemd[1]: Starting Plex Media Server for Linux…
Sep 03 16:28:23 raspberrypi systemd[1]: Started Plex Media Server for Linux.
lines 1-11/11 (END)
Please post the Server log /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs/Plex Media Server.log. The following command will output the last 40 lines: tail -n40 /var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Logs/Plex\ Media\ Server.log.
Also show us the file permissions of /var/lib/plexmediaserver/Library, e.g. with ls -ahl /var/lib/plexmediaserver/Library.
sudo /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs/Plex Media Server.log
sudo: /var/lib/plexmediaserver/Library/Application: command not found
2.
sudo tail -n40 /var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Logs/Plex\ Media\ Server.log
Sep 03, 2018 10:56:08.670 [0x744ea3b0] DEBUG - [com.plexapp.agents.imdb] Killing.
Sep 03, 2018 10:56:08.670 [0x744ea3b0] DEBUG - [com.plexapp.agents.plexmusic] Killing.
Sep 03, 2018 10:56:08.671 [0x744ea3b0] DEBUG - [com.plexapp.agents.plexthememusic] Killing.
Sep 03, 2018 10:56:08.671 [0x744ea3b0] DEBUG - [com.plexapp.system] Killing.
Sep 03, 2018 10:56:08.671 [0x744ea3b0] DEBUG - [com.plexapp.agents.themoviedb] Killing.
Sep 03, 2018 10:56:08.671 [0x744ea3b0] DEBUG - [com.plexapp.agents.thetvdb] Killing.
Sep 03, 2018 10:56:08.671 [0x744ea3b0] DEBUG - Waiting for Plex DLNA Server to exit.
Sep 03, 2018 10:56:08.772 [0x6e1ff400] INFO - Network Service: Abandoning advertise socket, it was closed.
Sep 03, 2018 10:56:08.793 [0x6fd31400] DEBUG - Jobs: ‘/usr/lib/plexmediaserver/Plex DLNA Server’ exit code for process 1463 is -15 (signal: Terminated)
Sep 03, 2018 10:56:08.793 [0x6d17e400] DEBUG - Plex DLNA Server exited.
Sep 03, 2018 10:56:08.806 [0x6fd31400] DEBUG - Jobs: ‘/usr/lib/plexmediaserver/Plex Tuner Service’ exit code for process 1466 is 0 (success)
Sep 03, 2018 10:56:08.834 [0x6c97e400] DEBUG - Plex Tuner Service exited.
Sep 03, 2018 10:56:08.834 [0x744ea3b0] DEBUG - Server is already in shutdown mode, ignoring this signal…
Sep 03, 2018 10:56:08.834 [0x744ea3b0] DEBUG - Waiting for Plex Tuner Service to exit.
Sep 03, 2018 10:56:08.940 [0x744ea3b0] DEBUG - Database: Shutting down.
Sep 03, 2018 10:56:08.940 [0x744ea3b0] DEBUG - Captured session 0.
Sep 03, 2018 10:56:08.940 [0x744ea3b0] DEBUG - Captured session 1.
Sep 03, 2018 10:56:08.940 [0x744ea3b0] DEBUG - Captured session 2.
Sep 03, 2018 10:56:08.940 [0x744ea3b0] DEBUG - Captured session 3.
Sep 03, 2018 10:56:08.940 [0x744ea3b0] DEBUG - Captured session 4.
Sep 03, 2018 10:56:08.941 [0x744ea3b0] DEBUG - Captured session 5.
Sep 03, 2018 10:56:08.941 [0x744ea3b0] DEBUG - Captured session 6.
Sep 03, 2018 10:56:08.941 [0x744ea3b0] DEBUG - Captured session 7.
Sep 03, 2018 10:56:08.941 [0x744ea3b0] DEBUG - Captured session 8.
Sep 03, 2018 10:56:08.941 [0x744ea3b0] DEBUG - Captured session 9.
Sep 03, 2018 10:56:08.941 [0x744ea3b0] DEBUG - Captured session 10.
Sep 03, 2018 10:56:08.941 [0x744ea3b0] DEBUG - Captured session 11.
Sep 03, 2018 10:56:08.941 [0x744ea3b0] DEBUG - Captured session 12.
Sep 03, 2018 10:56:08.941 [0x744ea3b0] DEBUG - Captured session 13.
Sep 03, 2018 10:56:08.941 [0x744ea3b0] DEBUG - Captured session 14.
Sep 03, 2018 10:56:08.941 [0x744ea3b0] DEBUG - Captured session 15.
Sep 03, 2018 10:56:08.942 [0x744ea3b0] DEBUG - Captured session 16.
Sep 03, 2018 10:56:08.942 [0x744ea3b0] DEBUG - Captured session 17.
Sep 03, 2018 10:56:08.943 [0x744ea3b0] DEBUG - Captured session 18.
Sep 03, 2018 10:56:08.943 [0x744ea3b0] DEBUG - Captured session 19.
Sep 03, 2018 10:56:09.029 [0x744ea3b0] ERROR - SQLITE3:(nil), 2570, os_unix.c:35002: (13) unlink(/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal) - Permission denied
Sep 03, 2018 10:56:09.031 [0x744ea3b0] DEBUG - Database: Shutting down.
Sep 03, 2018 10:56:09.031 [0x744ea3b0] DEBUG - Captured session 0.
Sep 03, 2018 10:56:09.031 [0x744ea3b0] DEBUG - Captured session 1.
Sep 03, 2018 10:56:09.154 [0x744ea3b0] ERROR - SQLITE3:(nil), 2570, os_unix.c:35002: (13) unlink(/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.blobs.db-wal) - Permission denied
pi@raspberrypi:~ $ ls -ahl /var/lib/plexmediaserver/Library
total 12K
drwxr-xr-x 3 pi pi 4.0K Sep 3 10:47 .
drwxr-xr-x 3 pi pi 4.0K Sep 3 10:47 …
drwxr-xr-x 3 pi pi 4.0K Sep 3 10:47 Application Support
PMS uses Linux user plex, not pi but for whatever reasons you have changed the owner of the PMS data to pi. That’s wrong. Simple fix: sudo chown -R plex:plex /var/lib/plexmediaserver. Then restart PMS: sudo systemctl restart plexmediaserver.
Ok. I ran both of those
still doesnt pull up on the site (IP):32400/web/
New logs please :wink:
pi@raspberrypi:~ $ sudo tail -n40 /var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Logs/Plex\ Media\ Server.log
Sep 04, 2018 07:59:03.685 [0x66dff400] DEBUG - IVA: Downloaded 32 trailers for source 1.
Sep 04, 2018 07:59:03.941 [0x66dff400] DEBUG - IVA: Downloaded 55 trailers for source 2.
Sep 04, 2018 07:59:04.419 [0x717ff400] DEBUG - NetworkInterface: received Netlink message len=56, type=RTM_NEWLINK, flags=0x0
Sep 04, 2018 07:59:04.419 [0x717ff400] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=3, flags=0x1003, change=0x0
Sep 04, 2018 07:59:04.420 [0x717ff400] DEBUG - Network change.
Sep 04, 2018 07:59:04.420 [0x717ff400] DEBUG - NetworkInterface: Notified of network changed (force=0)
Sep 04, 2018 07:59:04.420 [0x717ff400] DEBUG - Network change notification but nothing changed.
Sep 04, 2018 08:00:04.420 [0x717ff400] DEBUG - NetworkInterface: received Netlink message len=56, type=RTM_NEWLINK, flags=0x0
Sep 04, 2018 08:00:04.420 [0x717ff400] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=3, flags=0x1003, change=0x0
Sep 04, 2018 08:00:04.420 [0x717ff400] DEBUG - Network change.
Sep 04, 2018 08:00:04.420 [0x717ff400] DEBUG - NetworkInterface: Notified of network changed (force=0)
Sep 04, 2018 08:00:04.421 [0x717ff400] DEBUG - Network change notification but nothing changed.
Sep 04, 2018 08:00:33.791 [0x6b1ff400] DEBUG - BPQ: [Starting] -> [Processing]
Sep 04, 2018 08:00:33.830 [0x6b1ff400] DEBUG - BPQ: generating queue items from 0 generator(s)
Sep 04, 2018 08:00:33.830 [0x6b1ff400] DEBUG - BPQ: generated 0 item(s) for queue
Sep 04, 2018 08:00:33.834 [0x6b1ff400] DEBUG - PlayQueue: 0 generated IDs compressed down to a 2 byte blob.
Sep 04, 2018 08:00:33.835 [0x6b1ff400] DEBUG - PlayQueue: 0 generated IDs compressed down to a 2 byte blob.
Sep 04, 2018 08:00:33.845 [0x6b1ff400] DEBUG - BPQ: [Processing] -> [Idle]
Sep 04, 2018 08:00:49.824 [0x68dff400] DEBUG - Request: [127.0.0.1:35324 (Loopback)] GET /servers (3 live) GZIP
Sep 04, 2018 08:00:49.862 [0x71fff400] DEBUG - Completed: [127.0.0.1:35324] 200 GET /servers (3 live) GZIP 37ms 495 bytes
Sep 04, 2018 08:00:49.884 [0x6b1ff400] DEBUG - Request: [127.0.0.1:35326 (Loopback)] GET /library/sections (3 live) GZIP
Sep 04, 2018 08:00:49.898 [0x727ff400] DEBUG - Completed: [127.0.0.1:35326] 200 GET /library/sections (3 live) GZIP 15ms 475 bytes
Sep 04, 2018 08:00:49.917 [0x68dff400] DEBUG - Request: [127.0.0.1:35328 (Loopback)] GET /channels/all (3 live) GZIP
Sep 04, 2018 08:00:49.924 [0x727ff400] DEBUG - Completed: [127.0.0.1:35328] 200 GET /channels/all (3 live) GZIP 6ms 387 bytes
Sep 04, 2018 08:01:04.424 [0x717ff400] DEBUG - NetworkInterface: received Netlink message len=56, type=RTM_NEWLINK, flags=0x0
Sep 04, 2018 08:01:04.425 [0x717ff400] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=3, flags=0x1003, change=0x0
Sep 04, 2018 08:01:04.425 [0x717ff400] DEBUG - Network change.
Sep 04, 2018 08:01:04.425 [0x717ff400] DEBUG - NetworkInterface: Notified of network changed (force=0)
Sep 04, 2018 08:01:04.425 [0x717ff400] DEBUG - Network change notification but nothing changed.
Sep 04, 2018 08:02:04.416 [0x717ff400] DEBUG - NetworkInterface: received Netlink message len=56, type=RTM_NEWLINK, flags=0x0
Sep 04, 2018 08:02:04.416 [0x717ff400] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=3, flags=0x1003, change=0x0
Sep 04, 2018 08:02:04.416 [0x717ff400] DEBUG - Network change.
Sep 04, 2018 08:02:04.416 [0x717ff400] DEBUG - NetworkInterface: Notified of network changed (force=0)
Sep 04, 2018 08:02:04.417 [0x717ff400] DEBUG - Network change notification but nothing changed.
Sep 04, 2018 08:03:04.417 [0x717ff400] DEBUG - NetworkInterface: received Netlink message len=56, type=RTM_NEWLINK, flags=0x0
Sep 04, 2018 08:03:04.417 [0x717ff400] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=3, flags=0x1003, change=0x0
Sep 04, 2018 08:03:04.417 [0x717ff400] DEBUG - Network change.
Sep 04, 2018 08:03:04.417 [0x717ff400] DEBUG - NetworkInterface: Notified of network changed (force=0)
Sep 04, 2018 08:03:04.418 [0x717ff400] DEBUG - Network change notification but nothing changed.
Sep 04, 2018 08:03:04.678 [0x705ff400] DEBUG - Gracenote: Loading 29 locales in 254.3 seconds.
pi@raspberrypi:~ $ pi@raspberrypi:~ $ ls -ahl /var/lib/plexmediaserver/Library
bash: pi@raspberrypi:~: command not found
ok i can access it, now it is not showing all of my file folders inside my external hdd
That’s a typo on your side :wink:
That’s a text file. You cannot “execute” it :wink:
Your network connection is unstable. Check the cable.
have better cables but no screen close enough to use them. usually use good short cable except when i run updates and program, i have to use long cables.
so the HDDs that i have are not listed there. I have a 3tb fat32 and an 8 tb exfat
previously, i just plugged them in and everything ran great. I updated the server and it all died and i had to start over hence the problems you have been so kind to help me with.
so this is what it looks like.
but the suggestions for the other types of HDD dont seem relevant. Any suggestions? You have been a great help so far thank you, it is almost back to working again.
I got it THANK YOU SOOOOO MUCH! :grin:now time to reload everything::tired_face:
