All: I continue to play with RasPlex and various streaming alternatives.
I have installed RasPlex and set it’s name (to be different than another one in the house), I have modified the config.txt file to comment out the lirc.rpi line and uncomment the line for the hifiberry digi.
I have it on my network - running on wifi. I have set the audio device to be the Hifiberry.
The result is that I have a connection, but stuttered music playback. 2 or 3 seconds on, then no sound for 2 or 3 seconds, then another couple of seconds of music. Plex is playing the whole song.
I am using the NAD D 1050 DAC (new today). It is showing a sampling rate of 44.1 on its display. I am pretty sure most of the files I am testing are .flac encodings.
For comparison, I have another RasPlex running on a RasPi2 with the Hifiberry Amp and it has no problems running off the same library of .flac files.
Assuming you do have a Digi+ for the RPi2, the WiFi is probably the issue for something like FLAC, it can’t get the file with low enough latency to keep the buffer full. Try it on a wired connection and see if the problem persists.
I have been wondering the same thing. I will try again, but the other RasPlex I have running in the house is further away from the router and has no issues. Further, we stream video from the same Plex Media Server wirelessly to laptops and a Chromecast.
I will try to set-up a hardwired connection to see if that is it.
Which WiFi dongle are you using, the Edimax ones seem a bit lethargic in the last two releases, on my headless audio system I swapped out to a cheap Ralink chipset adapter (£4) that is rated at 300 not 150 (not that you ever get anything like that speed), little bit longer than a nano but throughput seems better especially with flac and lossless wma files, just a thought. Next release uses latest firmware and drivers so hopefully things may improve.
I am using one of the Realtek 8188 based dongles. Unfortunately, I had a quick look and the other ones I have hanging around here are based on the same chip. I am experimenting a bit more and the .mp3 or .wma files play well, it is the .flac ones that give me trouble.
@hetbeest said:
I have a RP2, DIgi+ connected to 100Mb UTP. Coax to my DAC. Still 44.1 KHz on my display. What could be the reason for that?
I will play with it tonight. I will post back. I will do some research on the settings within the Plex Media Server to see if it is doing any transcoding before streaming the files.
I had another look. One flac24 leads to 44.1KHz, the other (other artist) leads to 96KHz. Both downloaded from Bowers & Wilkins Society of Sound. Strange.
