All,
Ok, just got my Pi2, D/L latest installer and 0.5.1, installed to new 8Gb SAN Micro SD, first had the multicolour screen, added the "boot_delay=1" to config.txt, now get a black screen.
Any pointers would be good.
Warren
All,
Warren
When running the installer, did you select Raspberry Pi 2, not Raspberry Pi, as the device?
All,
Warren
The multicolour screen is fine, the first boot can take some time whilst it initialises the system, expands the file system, copies files, etc. Have patience.
A boot_delay of 1 is insignificant, you don't really need it.
Are you connecting to a monitor or TV?
Yes definatly set pi2, and connecting to a hdtv, how long for the multicolour screen?
Thanks for your help.
Warren
Warren
Only for a second, if it's longer than that I would suggest reflashing, making sure you select the correct device, as your card seems corrupt, make sure you eject the card properly before removing from your PC/Mac.
Regards
Ok, sorry if I sound brief and abrupt, out with the missus and just want to go home and play.
I have re- flashed several times, now I get no multicolour screen just black. I will go home and try a reformat and flash again but any other suggestions would be grateful.
P.s I have a 2amp sub power supply, so this has been tried.
Warren
Are you sure you installed the pi2 version and not the pi version of rasplex? it does make a difference :-)
