i experience an issue with both 0.6 and 0.7 version of rasplex.
i use my tv remote to control rasplex with CEC but i don’t want rasplex to change my tv channel at start.
so i’ve done these :
hdmi_ignore_cec_init=1 in config.txt (raspberry starting does not change my tv channel, good ! )
Make XBMC the active source when starting = false
when i uncheck “make XBMC the active source” then CEC does not work at all after a reboot but tv channel don’t change
do you know if there is a way to have CEC working great without having tv chanel auto change ?
so i’he done these :
best regards
Z
Disable hdmi_ignore_cec_init and set the CEC options correctly to suit your needs in Rasplex.
so i unchecked ‘make XBMC the active source …’ and that did the trick, after reboot rasplex does not change my tv channel.
but after a while watching tv, when i come back to rasplex, my remote don’t work anymore, i have to check '‘make XBMC the active source …’ and reboot to get remote back.
i have deactivate screensaver from rasplex.
