I’ve been trying to setup an OpenVPN connection from my Raspberry Pi 2 running Rasplex 0.7.0 to my ASUS RT-AC68U and I keep getting a connection failed. Is there anyone who has gotten this to work? I have multiple mobile users and a site2site working with this router already. I’m not sure what I’m overlooking here.
Appreciate the effort @NedtheNerd, but I’m using OpenVPN and it’s already deployed. Unfortunately, I cannot switch to PPTP without switching all my other clients. 2 of which are site2site VPNs that connect whole remote networks to me.
@benjaminwolf said:
Appreciate the effort NedtheNerd, but I’m using OpenVPN and it’s already deployed. Unfortunately, I cannot switch to PPTP without switching all my other clients. 2 of which are site2site VPNs that connect whole remote networks to me.
I’ve ssh’d in and was able to start the openvpn client with my config file, however I’m getting a TLS error over and over. Appears to be an issue with the OpenElec OpenVPN deployment with 0.0.7 as I have a windows client OpenVPN, iPhone, and iPad all connected using this same VPN server from the same remote wireless network.
Wed Aug 19 03:20:37 2015 OpenVPN 2.3.7 armv7ve-openelec-linux-gnueabi [SSL (OpenSSL)] [LZO] [EPOLL] [IPv6] built on Jun 16 2015
Wed Aug 19 03:20:37 2015 library versions: LibreSSL 2.1.7, LZO 2.08
Enter Auth Username:MYUSERNAME4OPENVPN
Enter Auth Password:
Wed Aug 19 03:20:44 2015 UDPv4 link local: [undef]
Wed Aug 19 03:20:44 2015 UDPv4 link remote: [AF_INET]SERVER_IP_ADDRESS:1194
Wed Aug 19 03:20:44 2015 WARNING: this configuration may cache passwords in memory – use the auth-nocache option to prevent this
Wed Aug 19 03:20:44 2015 TLS_ERROR: BIO read tls_read_plaintext error: error:1408D06E:SSL routines:SSL3_GET_KEY_EXCHANGE:bad dh p length
Wed Aug 19 03:20:44 2015 TLS Error: TLS object -> incoming plaintext read error
Wed Aug 19 03:20:44 2015 TLS Error: TLS handshake failed
Wed Aug 19 03:20:44 2015 SIGUSR1[soft,tls-error] received, process restarting
I may try installing just openelec and see if I can connect.
Thanks for all your help. Looks like this is a Rasplex issue. The following test was done using Raspberry Pi 2 with the same client.ovpn file as a configuration on the same remote network.
Using OpenElec 5.0.8, I was able to SSH and connect OpenVPN successfully using the same client config file. Rasplex 0.7.0 gives the same TLS error above.
OpenElec 5.0.8
OpenELEC (official) Version: 5.0.8
OpenELEC:~ # openvpn /storage/vpnconfig/client.ovpn
Sat Aug 22 22:30:14 2015 OpenVPN 2.3.5 armv7ve-openelec-linux-gnueabi [SSL (OpenSSL)] [LZO] [EPOLL] [IPv6] built on Mar 31 2015
Sat Aug 22 22:30:14 2015 library versions: LibreSSL 2.1, LZO 2.08
Sat Aug 22 22:30:14 2015 WARNING: file ‘/storage/vpnconfig/streetcred.txt’ is group or others accessible
Sat Aug 22 22:30:14 2015 UDPv4 link local: [undef]
Sat Aug 22 22:30:14 2015 UDPv4 link remote: [AF_INET]MY_ROUTER_IP_ADDRESS:1194
Sat Aug 22 22:30:14 2015 WARNING: this configuration may cache passwords in memory – use the auth-nocache option to prevent this
Sat Aug 22 22:30:21 2015 [RT-AC68U] Peer Connection Initiated with [AF_INET]MY_ROUTER_IP_ADDRESS:1194
Sat Aug 22 22:30:23 2015 TUN/TAP device tun0 opened
Sat Aug 22 22:30:23 2015 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Sat Aug 22 22:30:23 2015 /sbin/ip link set dev tun0 up mtu 1500
Sat Aug 22 22:30:23 2015 /sbin/ip addr add dev tun0 local 10.8.0.10 peer 10.8.0.9
Sat Aug 22 22:30:23 2015 Initialization Sequence Completed
^Z[1]+ Stopped openvpn /storage/vpnconfig/client.ovpn
And the Rasplex Error below:
Rasplex 0.7.0
RasPlex:~ # openvpn /storage/vpnconfig/client.ovpn
Sat Aug 22 23:02:23 2015 OpenVPN 2.3.7 armv7ve-openelec-linux-gnueabi [SSL (OpenSSL)] [LZO] [EPOLL] [IPv6] built on Jun 16 2015
Sat Aug 22 23:02:23 2015 library versions: LibreSSL 2.1.7, LZO 2.08
Sat Aug 22 23:02:23 2015 WARNING: file ‘/storage/vpnconfig/streetcred.txt’ is group or others accessible
Sat Aug 22 23:02:23 2015 UDPv4 link local: [undef]
Sat Aug 22 23:02:23 2015 UDPv4 link remote: [AF_INET]MY_ROUTER_IP_ADDRESS:1194
Sat Aug 22 23:02:23 2015 WARNING: this configuration may cache passwords in memory – use the auth-nocache option to prevent this
Sat Aug 22 23:02:23 2015 TLS_ERROR: BIO read tls_read_plaintext error: error:1408D06E:SSL routines:SSL3_GET_KEY_EXCHANGE:bad dh p length
Sat Aug 22 23:02:23 2015 TLS Error: TLS object → incoming plaintext read error
Sat Aug 22 23:02:23 2015 TLS Error: TLS handshake failed
Sat Aug 22 23:02:23 2015 SIGUSR1[soft,tls-error] received, process restarting
Does this need to go to the Rasplex team? Seems like the OpenVPN portion of the OpenElec wasn’t ported correctly, or the Rasplex 0.7.0 is using a version of OpenElec that had a bug in it?
Thanks for the info, this needs an issue raising, please refer to How to report a bug · RasPlex/RasPlex Wiki · GitHub and paste the info you supplied into it, together with the recommended additional info.
Just in case someone ran into this same problem, turned out the stock Asus RT-AC68U firmware has an older version of the OpenVPN server with a weak Diffie-Hellman key. Best solution is to switch to the enhanced merlin firmware. Best thing I’ve done to that router since I purchased it.
Kwiboo over at the Rasplex Issues page pointed out the logjam issue to me. Worth a read if someone’s reading this in the same boat.
