Rasplex and SNMP
Hi
Most of my computers here at home I use SNMP to monitor how they feel, even some of my Raspberry Pi
Now I like to install a SNMP on rasplex to see how it feel.
I know Watch Movie and that take alot if Power of a Raspberry Pi (I running v3, not B version) and I wonder if I going to have problem when I have SNMP going?
If not, how can I install SNMP client on rasplex, I did try to install like I did install on my other Raspberry Pi but he did not like that at all
Its not an easy task to install something that doesn´t come with rasplex without dpkg or apt-get installed.
Its not in the philosophy of rasplex but it´s doable.
What I have done to add these kind of unsupported features it´s to download the raspbian dpkg binaries and its dependencies, extract and move them inside the home folder and rebuild the necessary library paths.
You can check the plugins I made with this aproach to have some idea
or maybe you can try to use this plugin
http://openelec.tv/forum/unofficial-openelec-addons/72135-net-snmp-addon
Thanks going to see what I can do :slight_smile:
