Hi, i am trying to use my own custom background images but they are always showing blurry on rasplex. What size do the images need to be?
Best way to use custom background images is using deadeyeflint’s Plex Black Edition Skin. You can set blur/dim per image. Images should be => 720.
If you are modifying the default Plex skin any changes may be overwritten in future releases.
Regards
