ds24
November 29, 2013, 12:02pm
1
hi,
i´m looking for a smooth solution to use my nas server (without transcoding) to use plex
is it possible to get DTS with optical? spdif?
1080P mkv from nas (no transcoding)
how to remote the rasplex client?
my samsung tv has no smarthub, and blueray player cinavia copy protection
should this work?
celloch
November 29, 2013, 1:24pm
2
The Rasplex does not have an SPDIF output.
If you route the audio through HDMI and output from the SPDIF port on the TV to your receiver, the TV will downsample it to 2.0 channels (no Samsung TV, AFAIK, passes through untouched digital sound coming from HDMI sources, it works only with the DTV tuner).
ds24
November 29, 2013, 1:37pm
3
uhh, tnx for the answer, but i look for a useful solution to get dts / mkv with plex, is there anyway?
googletv no dts?
cubox still no dts?
blueray has cinavia copy protection!
android seems not 100 % compatible to dts?
:unsure:
epideme
November 29, 2013, 5:52pm
4
I use a 4x1 port HDMI switch with optical audio output between the Pi and the TV.
For me it works awesomely with DTS, AC3 or any other sound stream my amp can handle.
Search for hdmi 4x1 toslink on ebay.
celloch
November 29, 2013, 7:16pm
5
Yes I'd definitely suggest an HDMI switcher with separate audio output. If you want to use an rPi, it's your only option.
Otherwise you can check the Cubox-i and wait for a Plex package for it.
ds24
November 29, 2013, 7:26pm
6
hi
thank you for your help, i need anyway a switch because my tv got only 2 HDMI.
Sounds great ! thank you
ds24
January 18, 2014, 7:19pm
7
hi, i only want to say i bought a Pi and a switch, and now i am happy! only on / off is still a problem, how u realise That?
I get up and unplug it Sent from my iPhone using Tapatalk
Great that you got it working! :)
I feed my Pi power from the USB on my wifi repeater, so it's always on. The rest of the set I switch off with a remote power switch.
Not so sexy, but it works for me ;)
ds24
January 23, 2014, 6:48pm
10
i think that its not so good for the pi to be permanent online, and maybe it wake up my plex nas system ( hdd idle)?
i wil check :rolleyes:
theups
January 24, 2014, 1:52am
11
I power mine via usb from the TV. That way its only on when the TV is on.
luthien
January 24, 2014, 10:53am
12
Hi, I think i got a great solution.
I bought the RemotePi Board (a bit expensive :( )
https://forums.plex.tv/topic/84414-has-anyone-tried-the-remotepi-board/?hl=remotepi
I tried it and it works great. I use a cheap universal remote for TV and Raspberry. No mouse or keyboard anymore.
To keymap your Remote follow this guide:
https://github.com/RasPlex/RasPlex/wiki/GPIO-IR
Shutdown routine (use the openelec one):
http://msl-digital-solutions.myshopify.com/pages/more-information/
ds24
January 24, 2014, 4:15pm
13
thank you, Sounds nice
now i need more Time
Or you can check this: http://www.hifiberry.com/hbdigi
This is less expensive then a HDMI switch with toslink (S/PDIF) support...
Already a thread about the support for this hardware addon (HiFiBerry Digi/DAC):
https://forums.plex.tv/topic/98064-support-for-hifiberryinstalling-kernel-modules/
