Good.
I have installed my RasPLEX in my Raspberry 1 model B. The truth is that this very well, and is a fantastic way to use PLEX quite comfortably and fluently. The problem is that I can not showing me my playlists from movies, something which to me is very useful. It is quite confusing having to go looking for the movie I’m going to see. Much easier to add them to the lists.
Someone this happens and know if you have solution?
Best regards.
I also have this problem. There was one version of Rasplex I had installed that showed playlists, but it’s since been removed. I can’t find it in the options anywhere!
+1 Same issue here , any idea @NedtheNerd ?
Playlists are working fine in 1.0.3, find the movie, etc, press remote for context menu and select ‘Add to playlist’, if no playlist exists or not the one you want create a new one.
From personal preference I find it easier to create Playlists in PlexWeb.
Regards
