I'm not exactly sure when, but Rasplex doesn't show what the most recently added and whats on deck section on the main menu.
Normally when you navigate through the menu, when you hit categories like movies or tv shows or music, it will display recently added stuff on the right side.
I don't see that at all anymore, and i'm not actually sure I ever did.
Is it possible I disabled this somehow? or is this a glitch?
EDIT: Doing a Bit more research I've discovered this:
So currently I have 2 Computers running plex server now. I quickly setup another computer and installed Plex Server. So the original is plex (1) and the new one is plex (2).
After turning the plex server (2) on. And powering up my Rasp pi 2.
When I highlight anything on plex server (1) nothing shows on deck or recently added, when I highlight anything on the other plex server (2), it shows everything perfectly.
Lastly, I've connection a completly different pi to my Plex Server (1) and everything runs fine and shows up, just like the example above. I also recently installed plex client on a computer, and everything also shows fine when connecting to plex server (1)
i'm so lost.
Known issue. Workaround:
Settings | Network | Advanced Network Settings | Wait for network before starting XBMC should be selected.
