Rasplex running from usb
No issues here. Flashed the SD card and USB. Changed cmdline.txt file on the SD card with the I tried this "boot=/dev/sda1 disk=/dev/sda2 quiet oprofile.timer=1" and it booted fine.
I just did this with 0.3.0 and it worked fine.
boot=/dev/sda1 disk=/dev/sda2 quiet oprofile.timer=1  change to boot=LABEL=SYSTEM disk=LABEL=STORAGE quiet oprofile.timer=1
did the thing to me :) the new version dont have /etc/sda Oo anymore... ?   label your sd card SYSTEM and the USB Stick STORAGE
This worked great for me and was able to play higher bitrate video without a problem. My limit before this was around 8Mbps and worked perfectly with a 10Mbps file. Might crank a sample up and see what it can take :-)
I did have a problem when I restarted it errored with a '...file already exists...' error and would not proceed any further. I did have it powered via the TV but now powered to always on. Can anyone else replicate this?
By label the USB drive and SD card, do you mean name them that when formatting the drives?
Yes that is what he means. I got It working with the new cmd line however SSH seems to not work even after adding SHH to the command line. Any got SSH working on 0.3.0 or higher with a USB.
here is my current cmdline.txt file
boot=/dev/mmcblk0p1 disk=/dev/mmcblk0p2 ssh quiet
am runnng 0.3.1
this copy of file is located on usb
ssh is working properly
Is browsing around in the menus and sections faster now when you run it from the USB?
i find it faster yes, also no more corrupt sd cards :)
I flashed the USB drive and the Pi is now booting from SD and running from USB. No noticeable improvements, seems a little slower overall if anything. Going to give it some time to cache and see how it is then.
Make sure the USB device is a speedy one, otherwise you gain nothing from this.
Do you have any you can recommend?
Looking at this one: http://www.amazon.co.uk/dp/B007YXA5S8
I realise it's USB 3.0 but should still be speedy in the 2.0 port.
The Wirecutter agrees: http://thewirecutter.com/reviews/the-best-usb-3-0-thumb-drive/
However, I'm going to try with a Transcend Jetflash 700 16gb (ordered and on its way) as it's only $15/GBP10ish - for reference, an 8gb was about $13 at the time of writing so I went one up.. Hope that works but worse comes to worse I just have to upgrade.
hi,
i'm interested in checking this out, if i can find some 'extra' time...   :-p
i would like to know how good the udb drive needs to be in your opinion. do i need the best usb3 drive available, or just a good usb2 drive ?
thanks for your advice !
- scott
I tried using the windows installer on both my sd card and usb drive, but they have both been formatted at 249MB when they are both 16GB, is there any way to get the installer to format the whole card/drive?
hi,
- scott
On OpenELEC I used one of these http://www.amazon.co.uk/Lexar-JumpDrive-Flash-Drive-Memory/dp/B00B0YW9CW/ref=sr_1_1?ie=UTF8&qid=1382537610&sr=8-1&keywords=lexar+s23 pretty cheap but with really good performace, OpenELEC installed with one of those is a lot more responsive than I have managed to get RasPlex with just a class 10 SDHC, which is why I'm trying to get the USB working on RasPlex as well, see if it helps, but the installed formats the drive at just 249MB for both the sdhc and the usb drive I guess I'm going to have to do it manually as losing 15GB of space on both, so 30GB in total seems a waste.
249mb is the boot partition, if you look at drive with a program like GParted it will show you the other partitions
Rasplex works off of USB drive, where are you having problems getting this to work ?
Also no need to spend extra on USB3.0
I use a sandisk 8g 2.0 nano USB drive
249mb is the boot partition,, if you look at drive with a program like GParted it will show you the other partitions Rasplex works off of USB drive,, where are you having problems getting this to work ? Also no need to spend extra on USB3.0 I use a sandisk 8g 2.0 nano USB drive
there is a further 1.2gb partition on both, and 13.47 unallocated space on both
you can use GParted to expand the EXT4 partition
am runnng 0.3.1
I think this is wrong. The Cmdline text file must be on the SDcard for it to then boot on the USB. All you are doing currently is still booting off the SDcard.
That is the one on USB correct, I added the SSH to it to reenable it, the sdcard has a different config
to clarify between config files -
SDcard - "boot=/dev/sda1 disk=/dev/sda2 ssh quiet oprofile.timer=1"
USB flash - "boot=/dev/mmcblk0p1 disk=/dev/mmcblk0p2 ssh quiet"
