HI
I have tried to run it just off USB, will this work or do I have to do it with a SD card as well?
Cheers
HI
Cheers
RPI must have SD to boot from, so you need both. Just flash the image to both the USB and the SD using the installer, and then change the cmdline.txt file on the SD card as stated a few posts above.
Hi - As USB drives are being discussed here I thought is woulkd be the place for my problem. I was not getting any viewable output from running the RAsplex on the SD card so now run it on a new 16GB Transend Jetflash which is quite a fast drive. There is some improvement with the odd occassion of 'pausing' on H264 1080p files - still very annoying though. Is there any way and is it worth it to expand the partitioning on the USB? Currently it has the following partitions:
System(FAT)250mb(used)
Storage(Ext4)1.2GB
Unallocated 13.3GB
I would have thought that 1.2GB for the storage would be more than enough for a 2.6GB file. I take it taht all the caching/buffering is done the the storage section.
Also under the preferences/quality I get the best results at under 2 mbps - which is rubbish really.
I would appreciate any comments or ideas to improve the output.
many thanks
Richard
NOTE - I HAVE STARTED A NEW TOPIC ON THIS SUBJECT. - SORRY CAN'T SEE HOW TO DELETE THIS.
Storage(Ext4)1.2GB
Unallocated 13.3GB
many thanks
Richard
are you using wifi? then try wired.
rasplex will direct play 1080p from both sd card and usb. most problems with pi's are related to power supply or network.
Thanks for the reply - I am using a wired network on the pi with a seperate power supply
Hey,
i tried it with a generic USB thumb drive and the over clocking is more stable now. But the UI still feels slow. So i bought a Lexar USB 3.0 16 GB drive, pretty cheap but good speed.
Somehow it does not recognized if i use it on the raspberry usb port. If i use an USB hub it works. All other sticks work on the raspberry usb port.
Any ideas?
Ive just bought a nice USB3 drive, how will running it off the stick affect the updating process on the SD card, am i going to have to manually update the SD card and USB?
Sent from my iPad using Tapatalk
Trying to format my USB drive and it seems that rasplex places some sort of write protection onto it. I cannot format my USB drivE. Anyone have a solution. I have tried all the methods i could find online including using HP usb formating tool, regedits, rufus formatiing tool and using windows diskpart. Nothing has worked.
As always, very helpful dlanor.
How the heck are you all accessing your USB drive post setup to do things like add a remote.xml file or install a different skin? I am using Transmit for Mac to connect via SFTP and I don’t see any of the folders referenced in any of the posts elsewhere describing how to accomplish the above. Even tried SSH but again I seem to be getting dumped into the root of the SD card (but I don’t know for sure).
How the heck are you all accessing your USB drive post setup to do things like add a remote.xml file or install a different skin? I am using Transmit for Mac to connect via SFTP and I don't see any of the folders referenced in any of the posts elsewhere describing how to accomplish the above. Even tried SSH but again I seem to be getting dumped into the root of the SD card (but I don't know for sure).
I use Cyberduck (OSX - free) http://cyberduck.io/?l=en
You have to 'view hidden files' to 'see' all directories, careful what you change in the hidden directories!
To write to the boot partition (to edit config.txt using SSH) you have to remount it as read and write, if you don't know how to do this then search the forum, again, if you're not sure what you are doing then be careful what you change.
Were you aware that since 0.4.0-RC4 there is no longer any real gain from using a USB drive, stick with the SD card install.
Regards
Thanks for the info Ned. I will give CyberDuck a try. Will I easily be able to get to the usb drive or at least know what drive I'm working on? At the moment I am using only the SD card (a 4gb class 6) and it is noticeably slower so I'm still keen on trying to get the usb stick working..
[-_PHT Addons] path = /storage/.plexht/addons available = yes browsable = yes public = yes writable = yes root preexec = mkdir -p /storage/.plexht/addons------- Note that some of the folders shown here might not be visible in FTP or even in SSH (without correct “ls -a” parameter)[-_storage_plexht_temp area]
path = /storage/.plexht/temp
available = yes
browsable = yes
public = yes
writable = yes
root preexec = mkdir -p /storage/.plexht/temp[-_storage_cache area]
path = /storage/.cache
available = yes
browsable = yes
public = yes
writable = yes
root preexec = mkdir -p /storage/.cache
Thanks so much for the info dlanor. So if I have everything set up correctly, booting from the SD with Plex running off the USB, when I connect to the Rasberry Pi I via sftp, I can be positive that the "/storage" section I am looking at is in fact on the USB drive? I realized, thanks to NedtheNerds help that I needed to select "show hidden files" in my Transmit and Cyberduck programs to be able to see the file structure I was expecting to see. Without doing that, it made it seem like I wasnt getting to where I was supposed to be going.
That said I think I am just going to get a nicer SD card and do everything of of that. I want the performance boost of a USB drive setup since I am used to the snappiness of a real HTPC experience so i just assumed that i needed to go this route from the get go.
