Hi all,
Still using Rasplex and my 8Go card is full and does not charge any image from last show added (very very big collection).
So I bought 32Go one.
I installed from scratch but it failed after resizing : does not reboot.
When I manualy reboot : I have a corruption filesystem message.
=> Correction is applied and everything work fine, but image storage is about 27Mo (just enough to “precache” 100 shows or near)
So I tried to copy old SD-Card to the new, but it does not change anything.
Every time I expand the /dev/mmcb1k0p2 to the max via ssh : another booting corruption’s message apear, and no correction work… It said to reinstall Rasplex.
Need help to continue with Rasplex.
Raspberry 3
Sandisk class10 - 32g (before Sandisk class 10 - 8Go)
Rasplex 1.8.0.148 (as client only)
Thanks for you support in this issue.
