Rasplex - Update Experimental Rasplex
I've created a guide for those who want to update their experimental release without flashing their card and have to resetup everything.
https://www.dropbox.com/s/6tq0edxgosj6yob/Update%20Experimental%20Rasplex.pdf
Its pretty simple. You'll need a SSH client like Putty to do it.
Enjoy!
Nice guide, thanks, will try it with the next release (9.9.21)
Regards.
Looks nice but I get problems that my SD card is too small... Can't image my card is too small... It's like 8GB! How can I fix this?
Did you implement the 'growstorage' option on your existing SD card, doesn't happen automatically since 9.9.19?
Regards
How can I do that? I have nog 9.9.19. Can I do that trough ssh?
Edit the ‘cmdline.txt’ file in the /flash directory to add ‘growstorage’ to the end of the line, then reboot.
Regards
Thanks for the help but after editing the line it wouldn't boot anymore so I had to install the new version. I've added the "growstorage" option with the new install and it boots, so I hope I can use this method in the future.
Sorry to hear that, but at least you're up and running now.
Regards.
There is an easy way, enable Samba on Rasplex and drop the Kernal and System files in the update folder and reboot.
