Rating Tidal tracks in Plexamp
I’ve seen quite a few questions about this, and no answer, so I’ll try again…
Query: What does rating a tidal track in Plexamp (or probably any Plex app) actually do ?
I just want to be able to rate a tidal track and have it appear in my playlist, but it doesn’t :frowning_face:
Waiting
I think the functionality might be broken. There is a workaround solution, though: if you first add the Tidal track to library and then rate it in Plex, the track will add itself to your smart playlists.
It would be nice for @elan or someone else from Plex to tell us how it should work…
I’m not sure it does much of anything :sweat_smile: We sent it over to our cloud, I think we store it, but beyond that I’m not sure. We’d actually talked about making a playlist called “TIDAL :heart: tracks” which we’d add to when you highly rated a TIDAL track to work around that issue.
Ah OK, would be nice for it to do something, ideally make it add to a playlist
