Rear channels heard on side channels
Server Version#:
I recently set up 7.1.4 system. When I play multichannel files through appleTV the rear channel sound comes out of the sides. Nothing is coming from the rear channels. Other apps, like Apple Music and MAX sounds come out of correct speakers.
Download Channel ID 5.1 with H.264 from Dolby. You can use it to test your setup.
https://ott.dolby.com/OnDelKits/DDP/Dolby_Digital_Plus_Online_Delivery_Kit_v1.4.1/Test_Signals/muxed_streams/MP4/MP4_Muxed_Streams.html
My other Apple TV apps play 5.1 and other surround processing seamlessly. Only Plex has rear channels coming out of the side channels.
The video plays audio from each channel individually. It will help diagnose the problem. You can verify which channels are correctly/incorrectly mapped.
The left surround channel is incorrectly mapped to the left side channel and the right surround channel is incorrectly mapped to the right side channel. My question is why is it only Plex that has this incorrect mapping issue. My other Apple TV apps are mapped correctly.
Thanks. Now someone from Plex can recreate and diagnose.
I should also add that I am accessing my Plex files wirelessly from a windows PC.
FYI, here’s a 7.1.4 test video if you want to test all the channels. No idea if the ATV will play it. However, you might be able to load it on a USB stick and play it via your receiver/soundbar/etc.
Source: Proper surround test file(s) for Dolby Atmos .. please? | AVS Forum
Test file: https://download.dolby.com/us/en/test-tones/dolby-test-tones_7_1_4.mp4
I have used test tones and everything sounded correctly mapped. This issue is only an Apple TV PLEX app issue. Is there some setting in the PLEX media server that needs attention to correctly map these channels?
Someone from Plex will have to look into it.
I wasn’t implying you had anything set incorrectly. The 5.1 video was to verify how things were mapped, so someone can re-create when testing. The 7.1.4 video was just an FYI since you mentioned you had such a setup.
No problem. 5.1 setup has the same mismapping issue, too.
I can’t find any setting in the media server which maps speakers.
