Recent Playlists
Hi
I don’t care where this should be posted. I don’t care what anyone thinks I should “search” before posting. I don’t need opinions from readers or moderators.
What I want is to be rid of “Recent Playlists” on my Plex homescreen. I did not ask for it. I did not put it there. Please patch it out ASAP. Thank you and goodbye until next time my interface is hijacked. Seriously. Don’t add stuff to my screen for me. Remove it.
so glad you made your point. good for you :smiley:
I will give you the Plex answer in more blunt terms than Plex would usually use: It ain’t going to happen!
Plex controls the user interface and they alone know what is best for everyone and they know that everyone wants to use their Plex system in exactly the same way and if they don’t they are just wrong headed.
Everyone must want exactly the same interface because it is the Plex way and Plex is always right.
For me, although I use playlists I use the for only one thing, audiobooks, and I wish all reference to playlists could be hidden from the main screen except for the menu item on the left and that menu item should be placed at the bottom of the lost.
For me I only want to see playlists if I am specifically looking for them. However my wishes are not going to be implemented anymore than yours.
