REMOVE or HIDE selected/all Recent Playlists from Home Screen?
I have several Playlists I created for a few of my Libraries, but I want to hide SOME of the RECENT PLAYLISTS from appearing in the Recent Playlists on the Home Screen, is that possible?
Or if it’s not possible, is there a way to remove the Playlists completely from bottom of Home Screen, while still having it the Playlists “Pinned” on left menu for easy access?
Aren’t Playlists available from the top menu in Libraries, even when not pinned. Checked Plex for Mac, WebOS and Server, all have playlist in top menu of Library
Yes I’m aware of that situation, I would prefer not using more in this case
I’m good with it as is, but I can imagine others will argue the point. But as you suggest it may well be a better solution with Playlists being inert from the side bar. Maybe below more or in the Tool bar.
Well, I’m going to stay off that road of CW. Potholes are like craters… Lol
As for more control, it’s a slippy slop… Just one more setting, OMG. Were will it end is exactly right :upside_down_face:
