Is there any way to get the home screen recently added to update with newly added content without having to navigate away from the screen then back in again or relaunch OpenPHT?
It will eventually update on its own.
Regards
Is there a set time that this happens Ned? I’ve let it sit for at least 30 minutes after adding something to PMS and nothing has updated. Is it a once a day thing?
I use the Plex Black Edition Skin which has an option ‘Show On Deck/Recently Added immediately’.
Will check the default skin, which I assume you are using.
Regards
My apologies, have just checked the PBE skin, checking the option I mentioned doesn’t actually do what it states it does, the functionality is the same as the default skin - no auto refresh. I personally don’t find this an issue. However, if you wish to have this feature then can I suggest you open an issue on Github and label it as an ‘Enhancement’.
Regards
