Is there a way to have the “Recently Added” Section pull only from specific libraries? For Example, I have differently libraries split in a way where there are certain Genres for library. Some films are set in a way where they are pulled into multiple libraries. (Like Comedy and Family for instance). However, I also have an “#All Film” Library that is inclusionary of all of the other broken down libraries.
When I add a new film that may belong in multiple libraries, it shows up multiple times in the “Recently Added” list. I like the “Recently Added” Feature, but it would be convenient if it just pulled from the “#All Film” Library instead of pulling the multiples from all the different libraries. I’ve done the same thing with Television and Music, so if there is a way to do this (Or a way which could be added at some point) I would really appreciate it.
