At home, I use a mixture of an Android Box to connect to my Plex media server, and also I case to other TV’s in the house using Chromecast.
Going to be away a couple of times over the next month, and just wanted recommendations as to how I can access my Plex server. Are there any recommendations for devices that I can connect to the TV, to run Plex from?
You can always take the android box with you. They’re fairly small and portable.
Playing from your phone or tablet or laptop can work well. Do you know the setup for where you’ll be?
I’ve been using a Roku Streaming Stick+ and it runs nicely on the road. If the TV has a usb port, it often can use that for power. Roku even has a hotel mode, though I’ve never tried it:
I’d definitely recommend getting it set up in advance at home so it’s ready to use.
I use amazon firetv stick for that.
