Recommended Section of Libraries Unexpected Error NOT Loading
I have the latest version of PMS running on a Synology DS1019+. I have 6 Libraries (4K Movies, Movies, Adult Movies, TV Shows, Music and Home Videos). When I try to access the libraries with an7 user (I have 7 users), the Recommended section of the Music and TV Show library shows the error message “There was an unexpected error loading this library”. I have tried everything to fix this with no luck…SOMEONE HELP.
Logs-2.zip (6.4 MB)
I appreciate the input…but I couldn’t figure out how to repair the database…so I just stopped the PMS and renamed the library folder and transcode folder and restarted PMS…only problem is I lost all my collections and movie art…which sucks…any solution for this?
I actually moved the database from my Mac to this DS1019+ and that is probably why it got corrupted…it hasn’t been acting right since…I deleted it…but I do have a backblaze backup.
I will try this…the Plex data is almost 300gb…so it will take awhile.
So I finally got the backup copied over…it worked pretty good…movies and tv shows are fine…but for some reason I cannot get my music to update album art from the files…I have attached my logs for any help you can give me…thanks.Logs.zip (9.2 MB)
so Local Media Assets should be at the top of the list?
