Recommended tests?
Is there a list of recommended tests one should perform when testing a new Community Supported Tuner? I got my ATI TV Wonder HD 650 PCI tuner up and running, and everything seems to be working fine. Not bad for a 10 year old tuner!
I’m fairly new to Plex, I didn’t know if there were certain edge cases that needed to be tested. Is there a way to tell which tuner is being used when watching live TV? I also have a HDHomerun Connect, so my only real test so far beyond initial setup was to record 3 channels at once, which went well.
I remove the other tuners, and let it try a recording, play it back, maybe test live tv from another device. Good to hear you got this working though. I might have to try my pci tv wonder to again.
