Server Version#: 1.15.1.707
Recording with special character at the end of the title not saving… PMS record the show but at the end… the show disappear and i have only an empty folder
Thanks!
Thanks!
Thanks for raising this. Would like to have a look at logs covering scheduling and recording an episode to see where the failure occurs
Well at my first topic you can see images…
I’ll will sent you log this week end !
Thanks!
Here’s the log …
you can see the errors on Plex Media Scanner Analysis.log
As you can see… PMS replace the “?” by a space
Mar 04, 2019 10:14:58.120 [19492] DEBUG - [MI] Opening input file: “L:\Plex Recording\Que sont-ils devenus \Season 01\Que sont-ils devenus - S01E09 - Episode 9.ts”
I thought the issue was this
Mar 04, 2019 10:14:57.943 [5732] ERROR - Error creating directory "L:\Plex Recording\Que sont-ils devenus \Season 01": boost::filesystem::create_directory: Le chemin dӡcc鳠spꤩfi顥st introuvable: "L:\Plex Recording\Que sont-ils devenus \Season 01"
Mar 04, 2019 10:14:57.943 [5732] ERROR - Couldn't rename file "L:\Plex Recording\.grab\f8447b01984c99960d69163bd4f5796175bbcc68\Que sont-ils devenus - S01E09 - Episode 9.ts" to "L:\Plex Recording\Que sont-ils devenus \Season 01\Que sont-ils devenus - S01E09 - Episode 9.ts": Le chemin dӡcc鳠spꤩfi顥st introuvable
Maybe ! But its the same error … you have a space after “Que sont ils devenus”
The title of the show is “Que sont ils devenu?”
But that was not the only issue. Some characters are not permitted in file / directory names, eg
Tthat would be why the question mark was changed
But the log shows issues also with this
what directory got created?
and what is this chemin text?
So illegal characters for file/folder names get replaced with spaces
Also excuse my French - so the Le chemin is part of an error message saying the specified path not found or something like that
sorry for my slow understanding of the issue -
Le chemin dӡcc鳠spꤩfi顥st introuvable is probably just logging of french text is going wrong and it is just something like The specified path is not found.
So the issue is that we replaced illegal characters by space and windows trims the names and the trailing space is gone
I have referred this to the development team
I am not sure why the other example the “!” was replaced by a space. Exclamation mark is allowed in folder/file names
The two examples you show ae
"J’ai raté mes rénos!"
"Que sont-ils devenus?"
Server Version#: [1.15.0.659]
If the title have special caracter at the end of the show… like this J’ai raté mes rénos!
Plex replace the ! by a space… and the file is just deleted
If you check the name of the folder directly on windows… i have no space …
and if i check the name on plex i have a space at the end…
Thanks!
I have combined the 2 forum topics you raised
Notice that you quoted 1.15.x release versions - but your logs are 1.14.1.5488
I know i downgraded the version because i have artifacts with OTA signal…
But it’s the same issue whatever if i have 1.14 or .1.15 versions …
I have a development build to make available to you to fix this issue. Please could you try it and let me know the outcome
If the issue remains, fresh diagnostics please
I will send you a private message with a link
