[Rel] HTTP Anidb Metadata Agent (HAMA)
I am officially forking the HTTP Anidb Metadata Agent (HAMA) made by Atomicstraberry and posted here: http://forums.plexapp.com/index.php/topic/66918-release-http-anidb-metadata-agent-hama/After having concerted with him by mail, i will take over but give due feedback, as he created it, and i would and could not have done it without his code first, as i didn't know Python before. Great language by hte way!!!
As discussed with him:
  • His name will always be part of the header as he created it and was kind enough to let me take over
  • I put the source on GIT: https://github.com/ZeroQI/Hama . i am new to git, so please be understanding...
  • I create a new thread to be able to control the new releases on this first post [this one]
The readme is located here:https://github.com/ZeroQI/Hama/blob/master/README.mdIt will indicate the changes since v0.4Major changes:
  • Title search 100% local using AniDB title database XML file.
  • TVDB and AniDB XML serie page download cached a week by default
  • TVDB Poster by default, downloading AniDB unique poster only if no TVDB poster present
  • ScudLee XML mapping file to convert AniDB id to TVDB id without TVDB search needed (removed from )
  • Studio when missing in AniDB
  • Collection for Movie sets from XML mapping file (and matching with AniDB related anime fields)
  • Using episode summary from TVDB when present
  • HTML links to the TVDB and AniDB in Serie and episode page (off by default)
  • Warning messages for community improvement (missing anidb poster, missing TVDB en poster, missing episode summary, studio variable in AniDB AND mappingfile, theTVDB id missing from mapping file)
  • Themes songs 30s, from plex server using tvdb id [http://wiki.plexapp.com/index.php/TV_Themes]
This should prevent AniDB banning, since no search is done, no poster is downloaded, just the serie XML by ID.I will modify this post with any new releases, i am polishing out the bugs for now:
  • Testing speed and accuracy. need information on performance
  • Tweaking HTML links when TVDB id not in list, alerts when episode summary empty, etc...
  • Test serie/movie within both serie and movie folder settings
You can browse the source code and replace it in place of v0.4 as a beta, but the XML files need to be in Resources folder at the same level as code one
 See github readme, that's the most recent one
How it works
Scanners show the files or not in plex. if it's not showing, it's the scanner fault
Agent when files are showing update the metadata. This agent:
   . match the title to the AniDB Database locally (no online query to AnidDB to prevent getting banned for a day). It use synonyms, and search titles in all languages. you can select the language order in plugin settings
   . use xml matching table to fing the TVDB serie ID.
   . use posters from ANiDB (off by default, because they are crap but the only source for Hentai posters) or by default TVDB (use high res constant resolution posters, but do not store Hentai, have fanart and seasons posters as well)
   . The XML mapping file comes from the XBMC AniDB mod plugin and all xmls are cached 2 weeks and downloaded automatically
   . Use TheTVDB for Anime Episode summaries (AniDB seem to not use summaries for episodes)
   . Use theme songs from Plex server (backlog of 2 years, no need to update themes for now) indexed on thetvdb id. I store them locally using the anidb id if you want to create your own packages (and share?) and therefore you can have the right season music theme song...
   . logs like missing episodes are generated, also contain links to update episode summaries and missing posters... Give back digitally to the community...
The XMLs are downloaded (cached for 2 weeks) and a copy is saved here and used in case of internet issue
   . anime-titles.xml, the AniDB title database, part of the AniDB HTTP API : http://anidb.net/api...e-titles.xml.gz decompressed (xml extension). this is parsed locally to find serie title matches
   . anime-list-master.xml   ScudLee's AniDB to TVDB xml mapping file, give studio and episode mapping list for te episode overview, downloaded from https://raw.github.c...list-master.xml
   . anime-movieset-list.xml ScudLee's movie collection (Because XBMC only support movie collection and the files were develloped for AniDB mod XBMC plugin), downloaded from https://raw.github.c...vieset-list.xml
Agents can only write data in data folder as binary objects or as dictionaries, but cannot create folders unfortunately (if i am wrong, let me know)
I use theses folders to cache all pictures, theme songs, since they are not cached by plex.
This way, even if you recreate the whole Plex anime folder entry, you do not have to download the same file again.
Known Issues:
People names in Kanji
Producers and actors names are using romaji name like anidb does. I have been requested for an option in Kanji
Unfortunatly in AniDB serie XML (example: http://api.anidb.net...over=1&aid=2656), the creator names are like that:
Gonzo
Iijima Hiroya
Kizaki Fuminori
Iijima Hiroya
The RZA
Okazaki Takashi
I would have to process one more XML [http://anidb.net/per...&creatorid=6692] to translate it in kanji, which means one more access to AniDB for each. I could create a local (or remote web) cache but for now that would require too much coding at the time. if an xml existed out of anidb with the name i would probably use it
Series with year in title
Plex remove the year from the scanner side before Hama receive it, i need to check if i could correct it by modding the scanner not to drop the year
Hentai with no poster?
TVDB doesn't list sport and porn so hentai will not be listed there, so no fanart, no banner, no (season) posters and no episode summary. The same happens if no tvdb entry is there, or if not in the mapping file yet.
Movies not being detected
You did use the serie agent for a movie didn't you ?
It's not showing so it's a scanner issue you dope.... Just put 01 after the movie name and it will be picked up and yes my wonderful agent manage this case, but will gather only serie type of information (no producer)
Test series name
   . Semi-colon: Chaos;Head, Steins;Gate, Myself;Yourself
   . Year: KissXSis (2010), Black Rock Shooter (2012), Fate Zero (2012), Seitokai Yakuindomo (2011), Tenjou Tenge (2005)
   . Exclamation mark: K-On!, K-On!!
   . Apostrophe: Seitokai Yakuindomo'
   . Love Live 2
   . Terra e..
   . Movies: Gekijouban Shakugan no Shana, Kowarekake no Orgel, Sora no Otoshimono Project Pink
   . Strange" has no match and no semicolon to blame
   . "Toaru Hikuushi e no Koiuta" had no tvdb match like "Onee-chan ga kita", "Jigoku Sensei Nube" and "Corpse Party Tortured Souls".
To Do
   . Package of Studio Logos (see post here). Will not work on that but somebody else can
   . Package of Theme Songs supported, but none exist (name convention: anidbid.mp3). Plex use 30s songs but use seasons, so a package of songs capped at 30s should share the same legality. will not work on that but local loading works
   . Get Plex to not crash when writing to Agent Data folders, but even with try except, it fails if folders not created already so outside my reach and plex has to fix
History
This in no longer accurate, missing all last year imrovements...
   . 2014-05-26
         - added better folder management for XMLs files
         - added support when data folders are missing
         - added clear-cache command for serie title to clear the cache
   . 2015-04-07
         - Scanner: season folders can include serie name (tvdb naming convention)
         - Scanner: removed parenthesis "()" and brackets ([], {}) groups in filename to increase recognition rate
         - Scanner: manage better multi-episodes (s01e01-02 weren't supported)
         - Scanner: added format Byousoku 5 Centimeter - 1 - The Chosen Cherry Blossoms - [RAW](3d312152) [Thx TiS]
         - Agent: removed bug crashing when op/ed present with no number
         - Agent: producer, writers code was broken for both movies and series, fixed [thx -MaNIaC-]
   . 2015-04-08
         - Agent: removed bug crashing with Anidb specials with anidb number and letter convention
   . 2015-04-11
         - Agent: series with absolute numbering  in tvdb will now have summaries
Check readme for download and install instructions
If you're going to use git and Github, just work on a master branch, and use tags and/or branches for the stable releases. Then other people can help out with development :)
you probably forgot to upload the resources folder of the bundle to github.
2013-08-17 19:45:08,251 (-4e50b490) :  INFO (__init__:138) - SearchByName (MediaContainer(art=None, noHistory=False, title1=None, title2=None, replaceParent=False),en,Amagami Ss,None)
2013-08-17 19:45:08,273 (-4e50b490) :  INFO (__init__:794) - xmlElementFromFile (anime-titles.xml, anime-titles.xml.gz) None
2013-08-17 19:45:08,274 (-4e50b490) :  DEBUG (__init__:798) - xmlElementFromFile - Loading XML file from Resources folder failed:anime-titles.xml
2013-08-17 19:45:08,275 (-4e50b490) :  DEBUG (networking:172) - Requesting 'anime-titles.xml.gz'
2013-08-17 19:45:08,276 (-4e50b490) :  INFO (__init__:802) - xmlElementFromFile - Loading XML from url failed: anime-titles.xml.gz
2013-08-17 19:45:08,277 (-4e50b490) :  CRITICAL (agentkit:930) - Exception in the search function of agent named 'HamaTV', called with keyword arguments {'openSubtitlesHash': '55706e36c4ebc303', 'episode': '11', 'episodic': '1', 'show': 'Amagami Ss', 'season': '2', 'filename': '%2Fmnt%2Fuser%2FMedia%2FAnimeTest%2FAmagami%20SS%2FSeason%2002%2FAmagami%20SS%20Plus%20-%2011v2%20-%20Morishima%20Haruka%20-%20Part%201%20Sexy%20[UTW][1280x720][HDTV][8CB212D1]%2Emkv', 'plexHash': '24bca57b7f40dbb782f365c9b571c78868e4ac08', 'duration': '-1', 'id': '31243'} (most recent call last):
  File "/mnt/cache/usenet/apps/PlexLibrary/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/agentkit.py", line 921, in _search
    agent.search(results, media, lang, manual)
  File "/mnt/cache/usenet/apps/PlexLibrary/Application Support/Plex Media Server/Plug-ins/Hama.bundle/Contents/Code/__init__.py", line 855, in search
    self.searchByName(results, lang, media.show, media.year)
  File "/mnt/cache/usenet/apps/PlexLibrary/Application Support/Plex Media Server/Plug-ins/Hama.bundle/Contents/Code/__init__.py", line 200, in searchByName
    matchedWords[word]= [sample]
AttributeError: 'NoneType' object has no attribute 'iterdescendants'
the agent can't find anime-titles.xml.gz, which should be in the resources folder.
Update:
had another look at your code.
one error is, that you have two lines defining ANIDB_ANIME_TITLES_URL. you need to remove the second one...
but even then, the agent can't load from the correct url (in the browser it works). possibly python can't open an gz file as xml.
so you'd need to first download it, extract and then open it locally
Update2:
well, there seems to be more in error with opening remote xml files... after downloading anime-titles.xml manually, the next xml file gives the same error
2013-08-17 20:12:25,966 (-4e4ce490) :  DEBUG (__init__:798) - xmlElementFromFile - Loading XML file from Resources folder failed:anime-movieset-list.xml
2013-08-17 20:12:25,980 (-4e4ce490) :  DEBUG (networking:172) - Requesting 'https://github.com/ScudLee/anime-lists/raw/master/anime-movieset-list.xml'
2013-08-17 20:12:27,820 (-4e4ce490) :  DEBUG (networking:200) - Not caching 'https://github.com/ScudLee/anime-lists/raw/master/anime-movieset-list.xml' (content type 'text/plain; charset=utf-8' not cacheable in Agent plug-ins)
2013-08-17 20:12:27,829 (-4e4ce490) :  INFO (__init__:802) - xmlElementFromFile - Loading XML from url failed: https://github.com/ScudLee/anime-lists/raw/master/anime-movieset-list.xml
Hi, thanks for the reply.
The resources folder needs:
   . anime-titles.xml, the AniDB title database, part of the AniDB HTTP API : http://anidb.net/api/anime-titles.xml.gz decompressed (xml extension)
   . anime-list-master.xml which is ScudLee's AniDB to TVDB xml mapping file, give studio and episode mapping list for te episode overview https://raw.github.com/ScudLee/anime-lists/master/anime-list-master.xml
   . anime-movieset-list.xml for the movie collection (Because XBMC only support movie collection and the files were for an XBMC plugin originaly) https://raw.github.com/ScudLee/anime-lists/master/anime-movieset-list.xml
I am still coding, and i did put the two xml mapping files and the AniDB title database in the resources Folder.
I did modify the source code to allow to pull from the web (using cache) the missing files. uploaded it just now
To try:
   . will try to change the metadata object type to see if a movie scanned by the TV series plugin can have Movie only attributes updated
To those testing, please give me a feedback, performance wise, and bugs or series/animes not working. once loaded, this scrapper is meant to be pretty fast... Was thinking of using collections to put the studio name or other data tags... Any preference ?
New feature:
   . support for theme musics from plex TVDB theme support.
     You can add theme song here for thetvdb: http://wiki.plexapp.com/index.php/PlexNine_PMS_ThemeMusic
     Source code for PlexThemeMusic: [https://github.com/plexinc-agents/PlexThemeMusic.bundle/blob/master/Contents/Code/__init__.py]
anidbid =12345   ### id from TheTVDB.com
THEME_URL = 'http://tvthemes.plexapp.com/%s.mp3'
if THEME_URL % anidbid not in metadata.themes: ### can add latter a file search in serie or specific folder (if you don't want files in each folder)
  metadata.themes[THEME_URL % anidbid] = Proxy.Media(HTTP.Request(THEME_URL % anidbid))
If popular, we could have the following lookups:
. local folder
. specific folder with all theme songs, using main title or AnimeID for naming
. web server with files names with "AniDB id.mp3" pattern for movies an series grouped in TheTVDB.com. Length should be 30s max to avoid legal issues.. might cause bandwith issues if the plugin went to be massivelly adopted.
I am surprised there is no torrent packages of the sort yet... I guess there need to be a working implementation to start that, i hope i start a trend... if you have such data for test purposes (30s or full music, will trim myself) please contact me. i need data for tests and will develop the function, will help for exemple blind audio quiz for anime fans...
Uploaded a new version, this one got no errors when scanning my anime series in progress folder.
It exports in 3 separate logs the alerts so you can update the databases to fix the issues (no poster, no description, tvdbid not in mapping xml file, etc...)
Please let me know of any bugs, and the performance..., pasting Hama logs with the error and last debug line if an error occured
[Edit: 2013-08-25]
Studio logos from http://forum.xbmc.org/showthread.php?tid=70398 [https://sites.google.com/site/anidblist/AnimeStudios.zip] seem to work but are tiny. after playing, it seems:
  . no logos name in folder include dots, dash, exclamation point but can contain + and some contain spaces
 . if a logo\\NAS\Plex\Library\Application Support\Plex Media Server\Plug-ins\Media-Flags.bundle\Contents\Resources\Studio
is detected, if you replace it in PMS, it won't refresh even after clearing the browser cache...
After some research, to update Plex, the Media-Flags.bundle is here: https://github.com/plexinc-plugins/Media-Flags.bundle/tree/master/Contents/Resources Source: http://forums.plexapp.com/index.php/topic/65514-studio-logos/
The substitutions.xml XML file [Plex\Library\Application Support\Plex Media Server\Plug-ins\Media-Flags.bundle\Contents\Resources\substitutions.xml] format is below, and can help mapping if the logo doesn't show:
hello, i cant download the attachment?
i just need an agent that can recognise anime movies (all my anime tv show are done nicely), but not my movies.
example, i have Bleach - Memories of Nobody (2006).mkv
i tried anidb meta agent, but no success.
New version with updated xml files attached to original post
Please let me know the issues you encounter.
There is separate html logs (contain links to update databases) in \\NAS\Plex\Library\Application Support\Plex Media Server\Plug-in Support\Data\com.plexapp.agents.hama\DataItems for:
   . tv themes
   . anime-lists
   . TVDB
   . AniDB
Hi guys, There have been few downloads, but no reply to the thread, so i do not know how well this works with other sets of series, or how it compares to the udp AniDB agent, so please, let me know how good it is...
I created separate logs that only keep unique information for feedback to thetvdb or anidb, so you can batch update...
The TV theme is using plex server that is based on thetvdb id...
You can request features, as i don't know what to do now...  Might consider automating the database and file download if enough people are using the agent, which i am not sure of...
So if you have any questions, or a serie has one of the titles in AniDB but isn't recognised, please let me know
You might need to update the database title and the mapping file manually for now...
don't know if its the scanner or the metadata, but I would like to the  HAMA to be able to separate the specials from the series if possible, like The Episode list on Anidb
Otherwise I think it works very well, have some problems with my OAD files, but can be the scanner to
It won't recognice Chaos Head for me, have tried to copy the name directly from anidb, but still don't work
AniDB indicates the main title is "Chaos;Head" and none of the spellings, short title, synonims include "Chaos;Head".
the semi-colon not being forbidden by file systems, if you rename the anime, it should be fine...
Anidb title list: http://anidb.net/perl-bin/animedb.pl?show=anime&aid=6088
Do you use BABS scanner? The url is http://forums.plexapp.com/index.php/topic/31081-better-absolute-scanner-babs/
OAD file extention ?
I use BABS to scan my anime with
OVA and OAD is the same, just diffrent names http://en.wikipedia.org/wiki/Original_video_animation
Any instructions on installing this (Windows Server 2008 - Plex 0.9.86) would be greatly appreciated.
Put it at the location below with the other.bundle files.
C:\Users\XXXXX\AppData\Local\Plex Media Server\Plug-ins
I grabbed a zip of the master on git and also the latest xml from ScudLee.
Ran it through a few anime titles... one of which had >100 episodes using BABS and Hama
Parsed fine and loaded up all the metadata
Going to run it through part of my collection and see if any issues occur
Format - Worked no problems
   English Title/English Title - EP.container
Alt Format - Also worked without issues but ignored the OVAs... I'm assuming this is intended since they don't exist in the xmls
   English Title/Series/English Title - EP.container
   English Title/OVA/English Title - VolumeNo.container
Thanks for your post Melator, i have very little feedback on my code, and previous buggy versions i release possibly didn't help its widespread use...
I am using a HP microserver N40L on which i installed DSM (the OS of synology NAS) that i downloaded on XPEnology.com (++ version has more drivers supported)
That allow to use alternate package servers to install 3rd party apps (sickbeard) but Plex is supported by default.
I have been moving houses and since i am a computer parts hoarder, and also have a day job, that is taking a lot of my time and i didn't do new development on the agent but on the other hand, i don't know what to improve as it pretty much work well for me, the studio icons are supported, multi language support is there, it logs the issue the user has a possibility to correct, etc...
The agent takes the posters from the tvdb not from anidb due to a fixed resolution hence fixed ratio. That also limited the anidb ban since we do one request per serie.
For windows the agent goes here: C:\Users\XXXXX\AppData\Local\Plex Media Server\Plug-ins
I am unsure if many of you use the clever html log generated (one instance of every warning present in them) to be able to update used databases easily as i wanted this agent to allow to benefit not only Plex users but all database users as it allow easy database update by including direct links when applicable
 Logs are located in DataItems since it's the only folder with write access available to the agents:
   . For me it's in \\NAS\Plex\Library\Application Support\Plex Media Server\Plug-in Support\Data\com.plexapp.agents.hama
   . For windows it should be in C:\Users\XXXXX\AppData\Local\Plex Media Server\Plug-ins\Data\com.plexapp.agents.hama
Here is the feedback logs description and one example of every feedback:
   . AniDB.htm
        - Aid: 00002 No poster present
   . Anime-list.htm    ScudLee;s XML file feedback
       - Aid: 00002 '3x3 Eyes' AniDB and anime-list are both missing the studio
       - Aid: 00002 '3x3 Eyes' AniDB have studio 'xxx' and XML have 'yyy'
       - Aid: 00002 '3x3 Eyes' has no matching tvdbid ('OAV') in mapping file
       - Aid: 00002 anime-list is missing the anidbid
   . Themes.htm       Plex TV theme support whose filename is based on TheTVDB.com id and last 30s max. Wouldn't mind somebody a package will all complete mp3 theme songs whose name would be the AniDB ID (to account for the seasons different songs)...
        - Aid: 00002 '3x3 Eyes' tvdbid: 70973 '3x3 Eyes' Missing theme song 3x3 Eyes' No English poster
        - aid: 00002 tvdbid:70973 s1e1 Overview Empty
On my debian box it's located here: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Data/com.plexapp.agents.hama/DataItems
I only see anime-list.htm and TVDB.htm in there though
I gave the Hama Movie scanner a whirl but it didn't pick up very many of my films.
I then updated from git today and re-ran the scan but nothing changed.. except when I hit refresh on the movie itself the metadata updated.
I've had other agents behave this way as well so I'm guessing something outside the agent or maybe plain old user error
Aside from the snag above everything worked out well.. Good job :)
Thanks for giving the path on your box and for the nice feedback :D
It only create the logs if needed. i wanted to provide a way to feedback info easily to update databases so the users in OCD update the databases;)
Would you mind posting some of the movie titles and the filename associated so i try to reproduce?
Also, if you have (Implementable) feature requests...
I retested it and after a few manual name fixes, poorly named on my part, it picked up just about everything.
The only film it still can't find is Rao Den Jun'ai no Sho and for some films like Patlabor 1/2, Inuyasha, Tenchi Muyou and the two Evangelion films it's using the same cover art even though I have the AniDB > TVDB set in the config.
Raoh Den Junai no Sho - Director's Cut.mkv  (I've tried manual searches and did find it on TVDB through my browser but can't for the life of me get it to pick it up)
The only thing changed since the previous attempt has been a few PMS builds... one which had the new scanner so maybe that made the difference.
Can't think of anything more to add... you're pulling in all the data I typically look for in a series/movie.
The TVDB is a database for TV series, not movies. It therefore cannot gather info that TheTVDB will not have, so no poster from thetvdb.
They can be included if anidb sets them as specials,and must be labeled as such.
For "Rao Den Jun'ai no Sho"  Anidb names it as S01e01 not a special from a serie.
did you try to label it as "Raoh Den Junai no Sho s01e01 [director's cut].mkv"
I do recommend BABS scanner...
