Thanks for fixing the recent metadata issues.
I have a couple of other issues that I notice on some of the series in my library.
The first problem is this:
Matching mostly works fine, but something must be going wrong when fetching the titles for the series. HAMA is set to prioritize x-jat titles (which equals anidb’s “Main title”, right?), but the title gets set to what seem to be one of the titles from the “Synonym”-pool that anidb has. This should not be normal behaviour, right?
For example:
“Juuni Kokuki” becomes “12 Kokuki”
and
“Air” becomes “Air TV”
and
“Psycho-Pass 2” becomes “PP2”
and
“Aa! Megami-sama! Sorezore no Tsubasa” becomes “Ah! My Goddess: Sorezore no Tsubasa”
The second problem is this:
Something weird happens with some of my episode files, especially double-episodes. Some files get separated out into their own season folders with parts of the file name as name. My naming convention goes like this (and I know it is not “recommended” standard, but bear with me):
“One Piece - E10 (2000-01-19) [480p_NA_MP3_2ch_XviD][K-F&AKUPX]”
gets identified as
“One Piece\Season 2000\01-19)”
In this case, shouldn’t the matching system be content once it sees the episode number, and not meddle with the other information behind it? Why would it not match this as episode 10, but instead change it into a NON-EXISTENT episode (which it calls “01-19 )” in season folder “2000”)? I would think “E10” would be higher priority than other numbers separated in parentheses?
Here is an excerpt from the scanner log:
“One Piece (1999) [anidb-69]” s0001e009 “One Piece - E09 (2000-01-12) [480p_NA_MP3_2ch_XviD][K-F&AKUPX].avi” “(2000-01-12)”
“One Piece (1999) [anidb-69]” s2000e001 “One Piece - E10 (2000-01-19) [480p_NA_MP3_2ch_XviD][K-F&AKUPX].avi” “5” “01-19 )”
It continues bugged all the way to episode 77, in which case it becomes normal again…
and example of double episode:
“One Piece (1999) [anidb-69]” s2005e002 “One Piece - E227-E228 (2005-03-27) [480p_HDTV_MP3_2ch_XviD][GeruSama.com].avi” “5” “03-27 )”
It is just so weird that it is inconsistent, as most episodes works fine, but some do not (E10-E76 + double episodes).
