[Release] MyAnimeList.net Metadata Agent
Agreed. But MyAnimeList.net does not have episode details for the Specials. So if I keep the folders like this…
High School DxD_Folder structure
then the Plex Setup looks like this…
But the actual Special episodes come up like this…
Same is the case with Season 2 OVA. It identifies the folder alright. But the file inside is still named as Episode 1
The Episode X is the default that the Agent falls back to when there is no metadata available.
Just looking into this a bit more It is a bit of a problem.
Multi Episode releases have episodes listed as different episodes. For example, High School DxD OVA has two episodes. But the High School DxD New OVA only has one episode which does not have a separate episode tab.
Which means that for Single episode releases there will not be a Metadata for the episode itself but rather added to the library item itself. The Metadata needs to be available for the episode individually so that the Agent can pull it and add the titles of the episodes from MyAnimeList and add it to the episode you have in Plex.
Unfortunately, that is an inconsistency from MyAnimeList because ideally, you would want to have a list of episodes on every release even if it is only just one episode.
As for the High School DxD Specials, it has multiple episodes, it has an Episode Tab but there are no episodes listed there as you can see here.
You’re right. At least in case of S01 Specials, there is hope if the episode details get updated some day, then your plugin can pick it up. But for the single episode OVAs, the problem will still persist.
One other option can be to put the single episode OVAs in a movie library in Plex. I tried that and it works out fine.
I’ve done that for many Anime shows which have feature length movies: Ghost in the Shell, Evangelion, Bleach…
For now, I’ve settled on the following arrangement:
and the seasons as
(I prefer the seasons that way :slight_smile: )
Thanks for all your help @Fribbtastic. I’m simply amazed by your passion and your patience to keep this thread alive for so long and taking time to reply to every one who comes here. :clap:t2: :clap:t2: :clap:t2:
Yes, that is also a possibility but really depends on how you want to Organize your Libraries. You could create a separate OVA library just to store those OVAs as a Movie. Since the Agent supports both TV-Show and Movie Library you can do whatever you want with it if you keep to the MyAnimeList naming and Episode ordering.
Thank you, I know out of first hand how frustrating it is to have some tool that you would want to use but it is too old and got abandoned. Since I use the MAL Agent myself I will keep offer support for it. And maybe soon I can switch to the official API back so that I can retire the outdated placeholder API but as long as the official API lacks the information we currently expect I don’t want to make the switch yet.
Daraku, any chance there is an issue going on with the server?
I’ve tried to match Pokemon, Pokemon Advanced Generation and Pokemon Diamond & Pearl (don’t judge me, it’s really for someone else) and while it matches, no metatdata or art is downloading.
This is happening on my VPS plex server and my local plex server.
API can search and returns results even for the ID.
Problem is that the title is missing… so MAL apparently has changed something in that regard again. I will look into it.
Okay, works again. I have to change the XPATH of the Atarashii API running on my VPS when that happens but since I now know where I have to make the changes and have everything setup that I get the new XPATH this is pretty fast figured out.
Still, you need to clear the HTTP Cache from Plex so that you can get a fresh metadata request or else you will still get the bocken response.
As always man, thanks a lot. Was starting worry new season is starting up, was worried about manually doing it :slightly_frowning_face:
I was just trying to update the metadata for a few shows (The Pokemone I listed above, Quanzhi Fashi IV and Maou Gakuin no Futekigousha). While it pulled the posters for the last 2, it did not pull them for any of the pokemon series and it also is not pulling metadata.
I’m not at home so I can’t check everything but the API seems to work fine.
Can you clear the agents log file and refresh the metadata and upload the log so that I can take a look when I’m back home?
there is no titles about anime ??
description of anime
MyAnimeList changed something on their site again which made the extraction of the Synopsis fail and always return “There is currently no synopsis for this title”. I changed that and it should work again.
Clear your HTTP cache to get a new set of Metadata.
thanks it works.
hello,
(A whisker away) movie anime.
Not detected not showing up in library.
How to Name movie ?
Nakitai Watashi wa Neko wo Kaburu
How to name special episode and folder name , also include Ova.
Specials and OVAs are their own release on MAL. So just like your question before please take the release name of the show on MAL and use that as the folder and filename of release.
There is two Version of episode what i can do.
for (One Piece)
how to name the episode. there is two version episode what should i do.
Follow the naming convention of the scanner you use. Or at least how plex is expecting multipart episodes.
Please check the official plex documentation first next time.
please I need any kind of help.
episode from 1 to 10 not showing up in plex.
All episode named from 1 to 945
