Remote access disappeared
Server Version#:1.43.5.12079
Under settings /remote access it continues to check the access but nothing happens
I can’t connect to Plex neither on my android phone nor my Google TV box.
It worked yesterday and I didn’t change settings .
Any suggestions on how to fix this?
Check your server certificate as a first step. Go to the Plex Media Server folder in your user local app data folder, then to the Cache folder. Is there a certificate.p12 file? If so, stop/quit plex, rename it certificate.p12.old, then start plex back up. It should download cert-v2.p12. See if that helps.
https://support.plex.tv/articles/202915258-where-is-the-plex-media-server-data-directory-located/
If that doesn’t help, I assume those devices are remote that you are trying to connect with since you reference remote access?
Is your port still forwarded? Does the port show open? https://canyouseeme.org/
Were you relying on UPnP? If so, the port may have closed. It’s best to manually specify a port in plex and then create the forwarding rule for the port on your router/gateway.
I think I found it :
Seems upload speed was left undefined .
As soon as I entered a value I was able to connect remotely .
