Remote Access - Set custom IP/URL
I’m in a complicated network infrastructure and thus the IP which must be used to access the instance is not the same as my public IP.
Thus I request the ability to set a custom IP:PORT/URL to access the instance.
It is currently possible to only set the port (See config -> Server -> Remote Access).
Note: While this request is not a common problem for many users it is the only feature I really need!
See Settings - Server - Network - ‘Show Advanced’
Disable ‘Secure Connections’ if you don’t have a fitting, trusted certificate for your public IP.
