I know this question has been asked several times but I wanted to get your opinion this specific scenario. I’m trying to enable Remote Access but keep getting the “Not available outside your network” error. Here’s what I’ve tried:
- Manually specifying port on Plex and forwarding ports on my router
- Turning Firewall completely off on the router
- Restarting router and Plex server
- Disabling then reenabling uPnP on the router
- Traceroute only shows my private IP on the first line, the others are public IPs
I’m currently using a Modem/Router combo supplied by my ISP. When I gave them a call, they insisted that the issue is because I need a Static IP; however, I’m under the impression that Plex handles all that automatically and I should still be able to access my content remotely, even with a dynamic public IP. Is this correct?
I also read that people advised checking sites like canyouseeme.org to see if the port is open. Unfortunately, every port I try comes back with a “Connection timed out” error. Could this be related to the issue I’m having?
Ultimately, I’d like your opinion:
- Does it sound like I have a Double-NAT situation and do I need to purchase a Static IP from my ISP?
- Why are all my ports timing out when using canyouseeme.org?
- Are there any other troubleshooting steps you would recommend?
Thank you!
