Router: Metgear RAX80
Server Version#: Version 4.8.3
Windows 10
I’ve set my Static IP Address
I’ve set a port forward numerous times, changing port number in router and Plex setting. UDP and HTP… Tried manually using 32400 first and have moved onto other port numbers.
Id stick with port 32400
You should specify TCP/UDP, there is no such thing as HTP
You should not be able to ping your PC from outside, just your external IP.
Please do the following
make sure you have disabled any windows firewall or allowed plex service/port
disable remote access in plex
setup a port forward for port 32400
enable remote access and specify port 32400
go to canyouseeme.org and check for success on port 32400
if it fails please post your port forwarding settings and blank out your public IP
I am in the United States and I am getting the same results as nsozou. I am using the local electric companies broadband that they offer. I have tried everything in the trouble shooting guide. I am trying to set up remote access for a friend in the UK. She moved there from the United States and is not much into the programming there. I have tried everything that you suggested in this forum so far. I am at a loss. Hope you can help. I have a Linksys WRT1200ac router for both networks on the property. Sometimes it will say that it is available outside the network, but only for a few seconds then goes back to not available. Thanks in advance.
Leave your firewall disabled while doing this
Download this https://sourceforge.net/projects/miniweb/
unzip and put the miniweb folder on your desktop
setup a port forward for port 8000 to the same IP as your plex server
run/double click the miniweb.exe file
use a browser and go to http://x.x.x.x:8000 where x.x.x.x is your internal IP
make sure you can see the blue miniweb default page
go to canyouseeme.org and check for port 8000
If this fails your ISP might be blocking inbound access and you might need to work with them to see how to get this allowed.
Explain that you are trying to create an inbound connection to a service you are hosting and having difficulty.
The public IP address 119.18.1 is part of a /24 which just means that that your ISP can only serve about 250 end users which isn’t alot and seems small/strange so they might be doing some weird stuff on their end to provide you internet access.
