Remote Access
Server Version#:
Player Version#: n/a
Currently receiving an SSL error when my server is trying to enable remote access. I’ve tried standard UPNP as well as specifying a manual port through the router.
I think this is the relevant snap from the logs:
[HttpClient/HCl#32e] HTTP error requesting GET https://184-58-4-75.PLEXTOKENREDACTED.plex.direct:51234/identity (60, SSL peer certificate or SSH remote key was not OK) (SSL certificate problem: unable to get local issuer certificate)
Go into the cache directory in the plex media server local app data folder for your user, is there a certificate.p12 file? If so, stop plex, rename it certificate.p12.old and start plex back up, it should download cert-v2.p12. See if that helps.
Also, stick to the manual port forward method, and disable UPnP on your router.
