Basically, the h264 video must be level 4 or lower or it will transcode, regardless of bitrate/size. A lot of videos are at level 4.1, which is how I ripped all of my videos. There could be a limitation on reference frames too (I know the Roku has that) but I couldn't find any info.
Devs know that the video can actually be played directly on most cases, and are working on a fix or work-around.
That's a possibility, but then it would transcode when the op tries to play locally. Since they're able to direct play locally it more than likely would be a setting on the remote end.
