Remove commercials
How can you pay to get rid of the commercials.
Which commericials?
If you have a dvr/tuner and are using it with plex to dvr from OTA, then you can check the settings > dvr settings > remove commercials, which will attempt to post-process any recordings and remove commercials.
if you are referring to the free live tv on plex or free plex movies and tv then the answer is: you cannot remove any ads. these content is free to everyone (no plex pass or server required), and are supported by ads. Plex pass does not remove them.
