Remove Default/Only SquareArt for Invincible (2021)
I know we can change the SquareArt ourselves, but can the default SquareArt for Invincible (2021) be removed? I don’t see it on FanArt, so assuming it’s coming from Gracenote. There’s only one option and it’s not relevant, unless I’m missing the connection, I just started the show. Thanks!
Edit: someone else pointed out it’s likely coming from this show: https://watch.outsideonline.com/series/vincent-luis-invincible/5oLQ0H25-b49sx65t?season=1
Thanks for reporting. Ugh… That shouldn’t have happened. Also great show!!!
The wrong image has been removed and replaced with another image that is from the correct show. It may take some time for the cache to expire to fetch the change.
If you haven’t already selected a squareArt option and you’re still seeing this incorrect option, running a Metadata Refresh on the show should fetch the new (correct) squareArt. Before you run the Metadata Refresh make sure any fields or other artwork you want to remain are locked.
Thanks, @Atomatth . I get the new one now. Appreciate it. :folded_hands:t4:
Also, the old picture eventually dropped off as well.
