I can add them, I can move them, I googled how to remove them and can’t find anything.
This was an issue for a while, but I believe it was recently fixed. Could you list the player version number? If you’re having trouble finding it, it’s in the settings menu at the bottom of the screen. It should look like 9.x.x.xxxxx (xxxxxxxx)
9.3.0.32977
How is it supposed to work?
long-press the item and select Delete/Remove from Playlist (sorry, loose translation based on my non-English UI).
Thanks lol, I never got this notification and finally just figured it out and was coming to post it
