Remove specific shows from Continue Watching
I have several shows that I added to a playlist that I shuffle late at night or during the day. How do I remove these shows from the continue watching? I know you can go through the PC and remove them that way but that only lasts a day and The shows come back on continue watching as soon as I shuffle the playlist again.
Click on info and then mark as played
I’ve done that. The issue is, is that the episode gets ended halfway through or something, so it stays on deck
Ah, we can remove an item from “Continue Watching” by doing certain things once it shows up, but there is no way to per-emptively prevent an item from being added to it.
“remove from continue watching” on the episode in CW from is menu on bottom right of poster. the only. It will remain off until you watch the show again.
Other than that the only other thing is to prevent the anything in library from appearing in any hubs/rows on home screen by editing the library and under Advanced choose Exclude from Homescreen
