Removing sources that are unavailable
Greetings, sorry to ask this, but I can’t find an answer in the support docs and the forum entries don’t seem to work either. I have a friend’s server that is gone; he changed the name, the new one is there and works, but I can’t remove the old one. I know this is user error, but thoughts please? Thanks.
Where exactly does the old one appear?
If it shows on the side bar right after opening the app, you must “unpin” these libraries.
If it only shows when you turn the sidebar into the “More…” mode, you only need to wait a few weeks. It will eventually vanish.
Thanks @OttoKerner, it’s on the web app and I think it’s pinned. I can’t figure out how to “unpin” it. I don’t see anything around it to provide options.
If you have any libraries from this server pinned to the left, you point at the library, and there should be a triple dot icon that appears on the right-side.
dot
Click it, and select the option Unpin
If you are referring to the server in the More > menu if you scroll to the bottom of your sidebar and click on More >, then I think that is what Otto is talking about.
Thanks all, I guess it’s under More, so I’ll wait and see.
