Removing transcoding limits
Hello,
Is there a way to remove realtime transcoding limits ? I am asking because I recently installed the synology-armv7 version in a Jetson Tegra K1 board. This board is at least 4x more powerful that the synology NAS. I have been able to play most of my library but some old versions that are in AVI/mpeg4 says the server is not powerful enough. I have set transcoding to “make the cpu suffer”. I know is capable because when I say optimize in the background it usually does 4.6x. So my question is: is there anyway to remove this transcoding limits?
No. The Armv7 versions don’t have the transcoding ability at all. It’s not a switch. There currently isn’t a version of PMS available for that board.
I can transcode it with the “optimize” command. Also sometimes realtime transcoding kicks in for example in this movie log you can see it in the log I pasted and also when I do a ps I see it
plex 6852 19.9 0.5 44824 9860 ? Sl 10:40 3:42 /home/plex/deployment/package/Plex Transcoder -codec:0 h264 -codec:1 dca -noaccurate_seek -i /mnt/media/movies/peliculas/Deadpool 2016 1080p BluRay x264 DTS-JYK/Deadpool 2016 1080p BluRay x264 DTS-JYK.mkv -map 0:0 -metadata:s:0 language=eng -codec:0 copy -map 0:1 -metadata:s:1 language=eng -codec:1 aac -ar:1 48000 -channel_layout:1 5.1 -strict:1 experimental -aac_coder:1 fast -q:1 0 -f matroska -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 - -start_at_zero -copyts -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/67sx591nic73z3bln1ryiafw/progress
Jan 02, 2017 10:40:17.530 [0xa9910400] DEBUG - Created thumbnail of size 300x450, has pixels: 1
Jan 02, 2017 10:40:17.552 [0xb38ff400] DEBUG - Completed: [192.168.1.144:49549] 200 GET /photo/:/transcode?url=http%3A%2F%2F127.0.0.1%3A32400%2Flibrary%2Fmetadata%2F364%2Fthumb%2F1482631594%3FX-Plex-Token%3Dxxxxxxxxxxxxxxxxxxxx027-474e-ad65-0ab6dc0b414f&width=300&height=450&minSize=1 (15 live) GZIP 378ms 23632 bytes (pipelined: 4)
Jan 02, 2017 10:40:17.604 [0xb3611400] DEBUG - Completed: [192.168.1.144:49551] 200 GET /photo/:/transcode?url=http%3A%2F%2F127.0.0.1%3A32400%2Flibrary%2Fmetadata%2F364%2Fart%2F1482631594%3FX-Plex-Token%3Dxxxxxxxxxxxxxxxxxxxx027-474e-ad65-0ab6dc0b414f&width=1920&height=1080 (15 live) GZIP 419ms 195696 bytes (pipelined: 2)
Jan 02, 2017 10:40:17.748 [0xb3323400] DEBUG - Request: [192.168.1.144:49551 (Subnet)] OPTIONS /video/:/transcode/universal/decision?hasMDE=1&path=http%3A%2F%2F127.0.0.1%3A32400%2Flibrary%2Fmetadata%2F364&mediaIndex=0&partIndex=0&protocol=http&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&session=67sx591nic73z3bln1ryiafw&offset=0&subtitles=burn&copyts=1&Accept-Language=en (15 live) GZIP Signed-in Token ()
Jan 02, 2017 10:40:17.748 [0xb38ff400] DEBUG - Completed: [192.168.1.144:49551] 200 OPTIONS /video/:/transcode/universal/decision?hasMDE=1&path=http%3A%2F%2F127.0.0.1%3A32400%2Flibrary%2Fmetadata%2F364&mediaIndex=0&partIndex=0&protocol=http&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&session=67sx591nic73z3bln1ryiafw&offset=0&subtitles=burn&copyts=1&Accept-Language=en (15 live) GZIP 0ms 528 bytes (pipelined: 3)
Jan 02, 2017 10:40:17.837 [0xb07d8400] INFO - [Chromecast] [MDE] Augmented profile: { "directPlay": { "mp4": { "mimeType": "video/mp4; codecs=\"avc1.42E01E\"", "video": { "codecs": { "h264": {} }, "maxBitDepth": 8, "maxFrameRate": 60, "maxLevel": 42, "maxWidth": 1920, "maxHeight": 1080 }, "audio": { "codecs": { "aac": { "maxSamplingRate": 48000 }, "mp3": {}, "ac3": {} } } }, "mkv": { "mimeType": "video/webm", "video": { "codecs": { "h264": {}, "vp8": {} }, "maxBitDepth": 8, "maxFrameRate": 60, "maxLevel": 42, "maxWidth": 1920, "maxHeight": 1080 }, "audio": { "codecs": { "aac": {}, "mp3": {}, "vorbis": { "maxChannels": 2 }, "ac3": {} } } } }, "directStream": { "video": { "codecs": { "h264": {} }, "maxBitDepth": 8, "maxLevel": 42, "maxWidth": 1920, "maxHeight": 1080 }, "audio": { "codecs": { "mp3": {}, "aac": {}, "opus": {} }, "maxChannels": 6 } } }
Jan 02, 2017 10:40:17.890 [0xb38ff400] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx027-474e-ad65-0ab6dc0b414f), enabling token-based authentication.
Jan 02, 2017 10:40:17.890 [0xb38ff400] DEBUG - Auth: authenticated user 1 as panitaxx
Jan 02, 2017 10:40:17.890 [0xb38ff400] DEBUG - Auth: Came in with a super-token, authorization succeeded.
Jan 02, 2017 10:40:17.890 [0xb2e66400] DEBUG - Request: [192.168.1.144:49549 (Subnet)] GET /video/:/transcode/universal/decision?hasMDE=1&path=http%3A%2F%2F127.0.0.1%3A32400%2Flibrary%2Fmetadata%2F364&mediaIndex=0&partIndex=0&protocol=http&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&session=67sx591nic73z3bln1ryiafw&offset=0&subtitles=burn&copyts=1&Accept-Language=en (14 live) GZIP Signed-in Token (panitaxx)
Jan 02, 2017 10:40:17.891 [0xb2e66400] DEBUG - Found session GUID of 67sx591nic73z3bln1ryiafw in session start.
Jan 02, 2017 10:40:17.892 [0xb2e66400] DEBUG - TranscodeUniversalRequest: using augmented profile Chromecast
Jan 02, 2017 10:40:17.893 [0xb2e66400] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/364?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx027-474e-ad65-0ab6dc0b414f
Jan 02, 2017 10:40:17.893 [0xb2e66400] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/metadata/364?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx027-474e-ad65-0ab6dc0b414f
Jan 02, 2017 10:40:17.894 [0xb38ff400] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx027-474e-ad65-0ab6dc0b414f), enabling token-based authentication.
Jan 02, 2017 10:40:17.894 [0xb38ff400] DEBUG - Auth: authenticated user 1 as panitaxx
Jan 02, 2017 10:40:17.895 [0xb38ff400] DEBUG - Auth: Came in with a super-token, authorization succeeded.
Jan 02, 2017 10:40:17.895 [0xad823400] DEBUG - Request: [127.0.0.1:49464 (Loopback)] GET /library/metadata/364 (14 live) GZIP Signed-in Token (panitaxx)
Jan 02, 2017 10:40:17.911 [0xad823400] DEBUG - It took 10.000000 ms to retrieve 107 items.
Jan 02, 2017 10:40:17.914 [0xad823400] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jan 02, 2017 10:40:17.914 [0xad823400] DEBUG - Selecting best audio stream for part ID 991 (autoselect: 0 language: en)
Jan 02, 2017 10:40:17.914 [0xad823400] DEBUG - Audio Stream: 2013, Subtitle Stream: -1
Jan 02, 2017 10:40:17.915 [0xad823400] DEBUG - It took 0.0 sec to serialize a list with 1 elements.
Jan 02, 2017 10:40:17.918 [0xb2e66400] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/library/metadata/364?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx027-474e-ad65-0ab6dc0b414f
Jan 02, 2017 10:40:17.918 [0xb38ff400] DEBUG - Completed: [127.0.0.1:49464] 200 GET /library/metadata/364 (14 live) GZIP 23ms 4136 bytes
Jan 02, 2017 10:40:17.920 [0xb2e66400] DEBUG - MDE: analyzing media item 991
Jan 02, 2017 10:40:17.920 [0xb2e66400] DEBUG - MDE: Deadpool (2016): Direct Play is disabled
Jan 02, 2017 10:40:17.921 [0xb2e66400] DEBUG - MDE: Deadpool (2016): no direct play video profile exists for http/mkv/h264
Jan 02, 2017 10:40:17.921 [0xb2e66400] DEBUG - MDE: Deadpool (2016): no direct play video profile exists for http/mkv/h264/dca
Jan 02, 2017 10:40:17.938 [0xb2e66400] DEBUG - MDE: Deadpool (2016): selected media 0 / 991
Jan 02, 2017 10:40:17.938 [0xb2e66400] DEBUG - Streaming Resource: Added session 0xade14e50:jv6pwcilynoffhwfp6uyds4i
Jan 02, 2017 10:40:17.939 [0xb2e66400] DEBUG - Streaming Resource: Reached Decision id=364 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=991 part=(id=991 decision=transcode container=mkv protocol=http streams=(Video=(id=2012 decision=copy width=1920 height=804) Audio=(id=2013 decision=transcode bitrate=768 encoder=aac channels=6 rate=48000))))
Jan 02, 2017 10:40:17.940 [0xb2e66400] DEBUG - It took 0.0 sec to serialize a list with 1 elements.
Jan 02, 2017 10:40:17.942 [0xb38ff400] DEBUG - Completed: [192.168.1.144:49549] 200 GET /video/:/transcode/universal/decision?hasMDE=1&path=http%3A%2F%2F127.0.0.1%3A32400%2Flibrary%2Fmetadata%2F364&mediaIndex=0&partIndex=0&protocol=http&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&session=67sx591nic73z3bln1ryiafw&offset=0&subtitles=burn&copyts=1&Accept-Language=en (14 live) GZIP 51ms 4157 bytes (pipelined: 6)
Jan 02, 2017 10:40:17.960 [0xa9eec400] INFO - [Chromecast] [MDE] Starting analysis of 1080 (mkv, h264, dca, 41, high)
Jan 02, 2017 10:40:18.292 [0xb3611400] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx027-474e-ad65-0ab6dc0b414f), enabling token-based authentication.
Jan 02, 2017 10:40:18.292 [0xb3611400] DEBUG - Auth: authenticated user 1 as panitaxx
Jan 02, 2017 10:40:18.292 [0xb3611400] DEBUG - Auth: Came in with a super-token, authorization succeeded.
Jan 02, 2017 10:40:18.292 [0xafc20400] DEBUG - Request: [192.168.1.144:49542 (Subnet)] GET /video/:/transcode/universal/start?hasMDE=1&path=http%3A%2F%2F127.0.0.1%3A32400%2Flibrary%2Fmetadata%2F364&mediaIndex=0&partIndex=0&protocol=http&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&session=67sx591nic73z3bln1ryiafw&offset=0&subtitles=burn&copyts=1&Accept-Language=en (14 live) Signed-in Token (panitaxx)
Jan 02, 2017 10:40:18.293 [0xafc20400] DEBUG - Found session GUID of 67sx591nic73z3bln1ryiafw in session start.
Jan 02, 2017 10:40:18.294 [0xafc20400] DEBUG - TranscodeUniversalRequest: using augmented profile Chromecast
Jan 02, 2017 10:40:18.295 [0xafc20400] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/364?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx027-474e-ad65-0ab6dc0b414f&checkFiles=1
Jan 02, 2017 10:40:18.295 [0xafc20400] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/metadata/364?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx027-474e-ad65-0ab6dc0b414f&checkFiles=1
Jan 02, 2017 10:40:18.297 [0xb3611400] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx027-474e-ad65-0ab6dc0b414f), enabling token-based authentication.
Jan 02, 2017 10:40:18.297 [0xb3611400] DEBUG - Auth: authenticated user 1 as panitaxx
Jan 02, 2017 10:40:18.297 [0xb3611400] DEBUG - Auth: Came in with a super-token, authorization succeeded.
Jan 02, 2017 10:40:18.297 [0xaf8b1400] DEBUG - Request: [127.0.0.1:49466 (Loopback)] GET /library/metadata/364 (15 live) GZIP Signed-in Token (panitaxx)
Jan 02, 2017 10:40:18.313 [0xaf8b1400] DEBUG - It took 10.000000 ms to retrieve 107 items.
Jan 02, 2017 10:40:18.319 [0xaf8b1400] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jan 02, 2017 10:40:18.319 [0xaf8b1400] DEBUG - Selecting best audio stream for part ID 991 (autoselect: 0 language: en)
Jan 02, 2017 10:40:18.320 [0xaf8b1400] DEBUG - Audio Stream: 2013, Subtitle Stream: -1
Jan 02, 2017 10:40:18.320 [0xaf8b1400] DEBUG - It took 0.0 sec to serialize a list with 1 elements.
Jan 02, 2017 10:40:18.323 [0xafc20400] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/library/metadata/364?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx027-474e-ad65-0ab6dc0b414f&checkFiles=1
Jan 02, 2017 10:40:18.323 [0xb3611400] DEBUG - Completed: [127.0.0.1:49466] 200 GET /library/metadata/364 (15 live) GZIP 26ms 4149 bytes
Jan 02, 2017 10:40:18.326 [0xafc20400] DEBUG - Cleaning directory for session 67sx591nic73z3bln1ryiafw ()
Jan 02, 2017 10:40:18.326 [0xafc20400] DEBUG - Starting a transcode session 67sx591nic73z3bln1ryiafw at offset -1.0 (state=3)
Jan 02, 2017 10:40:18.375 [0xafc20400] DEBUG - [Universal] Using local file path instead of URL: /mnt/media/movies/peliculas/Deadpool 2016 1080p BluRay x264 DTS-JYK/Deadpool 2016 1080p BluRay x264 DTS-JYK.mkv
Jan 02, 2017 10:40:18.379 [0xafc20400] DEBUG - Job running: FFMPEG_EXTERNAL_LIBS='/home/plex/deployment/Library/Application\ Support/Plex\ Media\ Server/Codecs/c9ea179-1157-linux-synology-armv7/' XDG_CACHE_HOME='/home/plex/deployment/Library/Application Support/Plex Media Server/Cache/' XDG_DATA_HOME='/home/plex/deployment/package/Resources/' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/home/plex/deployment/package/Plex Transcoder' '-codec:0' 'h264' '-codec:1' 'dca' '-noaccurate_seek' '-i' '/mnt/media/movies/peliculas/Deadpool 2016 1080p BluRay x264 DTS-JYK/Deadpool 2016 1080p BluRay x264 DTS-JYK.mkv' '-map' '0:0' '-metadata:s:0' 'language=eng' '-codec:0' 'copy' '-map' '0:1' '-metadata:s:1' 'language=eng' '-codec:1' 'aac' '-ar:1' '48000' '-channel_layout:1' '5.1' '-strict:1' 'experimental' '-aac_coder:1' 'fast' '-q:1' '0' '-f' 'matroska' '-avoid_negative_ts' 'disabled' '-map_metadata' '-1' '-map_chapters' '-1' '-' '-start_at_zero' '-copyts' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/67sx591nic73z3bln1ryiafw/progress'
Jan 02, 2017 10:40:18.567 [0xb38ff400] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Jan 02, 2017 10:40:18.567 [0xb38ff400] DEBUG - Auth: Came in with the master token, authorization succeeded.
Jan 02, 2017 10:40:18.567 [0xaff0e400] DEBUG - Request: [127.0.0.1:49467 (Loopback)] PUT /video/:/transcode/session/67sx591nic73z3bln1ryiafw/progress?index=0&id=0&codec=h264&type=video (14 live) Signed-in Token (panitaxx)
Jan 02, 2017 10:40:18.568 [0xb38ff400] DEBUG - Completed: [127.0.0.1:49467] 206 PUT /video/:/transcode/session/67sx591nic73z3bln1ryiafw/progress?index=0&id=0&codec=h264&type=video (13 live) 0ms 227 bytes
Jan 02, 2017 10:40:18.569 [0xb38ff400] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Jan 02, 2017 10:40:18.569 [0xb38ff400] DEBUG - Auth: Came in with the master token, authorization succeeded.
Jan 02, 2017 10:40:18.569 [0xad823400] DEBUG - Request: [127.0.0.1:49468 (Loopback)] PUT /video/:/transcode/session/67sx591nic73z3bln1ryiafw/progress?index=1&id=0&codec=dts&type=audio (14 live) Signed-in Token (panitaxx)
Jan 02, 2017 10:40:18.570 [0xb38ff400] DEBUG - Completed: [127.0.0.1:49468] 206 PUT /video/:/transcode/session/67sx591nic73z3bln1ryiafw/progress?index=1&id=0&codec=dts&type=audio (14 live) 0ms 227 bytes
Jan 02, 2017 10:40:18.592 [0xb2e66400] INFO - [Chromecast] [MDE] Finished analysis of 1080 (mkv, h264, dca, 41, high)
Jan 02, 2017 10:40:18.651 [0xb04ea400] INFO - [Chromecast]   canPlay: true
Jan 02, 2017 10:40:18.671 [0xb3611400] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Jan 02, 2017 10:40:18.671 [0xb3611400] DEBUG - Auth: Came in with the master token, authorization succeeded.
Jan 02, 2017 10:40:18.672 [0xa9eec400] DEBUG - Request: [127.0.0.1:49469 (Loopback)] PUT /video/:/transcode/session/67sx591nic73z3bln1ryiafw/progress?duration=6486.240000 (15 live) Signed-in Token (panitaxx)
Jan 02, 2017 10:40:18.672 [0xafc20400] DEBUG - Started session successfully: 67sx591nic73z3bln1ryiafw
Jan 02, 2017 10:40:18.672 [0xaa9ff400] DEBUG - Started universal transcode output thread
Jan 02, 2017 10:40:18.674 [0xaa711400] DEBUG - [TranscodeOutputStream] Input processing thread started at offset 0 for -1 bytes.
Jan 02, 2017 10:40:18.674 [0xa9eec400] DEBUG - It took 0.0 sec to serialize a list with 0 elements.
Jan 02, 2017 10:40:18.674 [0xb38ff400] DEBUG - Completed: [127.0.0.1:49469] 206 PUT /video/:/transcode/session/67sx591nic73z3bln1ryiafw/progress?duration=6486.240000 (14 live) 2ms 326 bytes
Jan 02, 2017 10:40:18.724 [0xaf8b1400] INFO - [Chromecast]   canDirectPlay: false```
That is only transcoding audio, which will work. You cannot transcode video.
