[Req#46c8/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x7f97147a18, 17, statement
Could I please get some help with the error in the subject line. My database in good working order and has been checked and fixed in @ChuckPa tool.
I think this is the issue but I run on raid (SHR). I wouldn’t know how to fix it. - plex-fix-db.sh · GitHub
from this reddit post - Reddit - Dive into anything
any help would be appreciated!
Server Version#:1.32.5.7318-7000
Plex Media Server Logs_2023-07-12_15-26-57.zip (7.9 MB)
No idea what tool you’re referencing is doing.
What I can offer you is this:
That’s the tool i was referencing. It doesn’t fix the issue.
Is there any other help available? like troubleshooting help? Problem solving help? All associated with PMS of course.
The tool you linked is not mine plex-fix-db.sh (this isn’t mine)
Looking through your logs, I see this:
Jul 12, 2023 15:26:05.536 [547508502752] INFO - [Req#453/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x7f87058a18, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
This happens when “Optimize Databases” has been selected (PMS is running) before PMS finishes the upgrade process (I see you are running 1.32.57318 – which is new)
The error isn’t really an error. It’s telling us it’s refusing to optimize the databases because the DB’s are still changing.
Here is where it’s changing:
Jul 12, 2023 15:24:25.205 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db/DatabaseFixups] Running database fix-ups completed in 2.6 seconds.
Jul 12, 2023 15:24:25.205 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Captured session 0.
Jul 12, 2023 15:24:25.205 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Captured session 1.
Jul 12, 2023 15:24:25.205 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Captured session 2.
Jul 12, 2023 15:24:25.205 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Captured session 3.
Jul 12, 2023 15:24:25.205 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Captured session 4.
Jul 12, 2023 15:24:25.205 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Captured session 5.
Jul 12, 2023 15:24:25.205 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Captured session 6.
Jul 12, 2023 15:24:25.205 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Captured session 7.
Jul 12, 2023 15:24:25.205 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Captured session 8.
Jul 12, 2023 15:24:25.205 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Captured session 9.
Jul 12, 2023 15:24:25.205 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Captured session 10.
Jul 12, 2023 15:24:25.205 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Captured session 11.
Jul 12, 2023 15:24:25.205 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Captured session 12.
Jul 12, 2023 15:24:25.205 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Captured session 13.
Jul 12, 2023 15:24:25.205 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Captured session 14.
Jul 12, 2023 15:24:25.205 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Captured session 15.
Jul 12, 2023 15:24:25.205 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Captured session 16.
Jul 12, 2023 15:24:25.205 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Captured session 17.
Jul 12, 2023 15:24:25.205 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Captured session 18.
Jul 12, 2023 15:24:25.205 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Captured session 19.
Jul 12, 2023 15:24:25.205 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Rebuilding full text search tables.
Jul 12, 2023 15:24:25.206 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Activity: updated activity ca8f460c-4a23-45a9-98ee-0d452cb263ce - completed 40.0% - Optimizing database
Jul 12, 2023 15:24:36.726 [547593236704] DEBUG - BPQ: [Starting] -> [Processing]
Right before you grabbed the ZIP file, it did finish optimizing the DB…
Jul 12, 2023 15:26:06.286 [547593236704] DEBUG - PlayQueue: 0 generated IDs compressed down to a 20 byte blob.
Jul 12, 2023 15:26:06.287 [547593236704] DEBUG - BPQ: [Processing] -> [Idle]
Jul 12, 2023 15:26:06.289 [547508502752] DEBUG - [Req#453/Database optimization/com.plexapp.plugins.library.db] Activity: Ended activity ca8f460c-4a23-45a9-98ee-0d452cb263ce.
Jul 12, 2023 15:26:43.228 [547643433184] DEBUG - WebSocket: client initiated close
Jul 12, 2023 15:26:43.228 [547643433184] DEBUG - NotificationStream: Removing because of close
Jul 12, 2023 15:26:43.240 [547643433184] DEBUG - handleStreamRead code 1: stream truncated
Jul 12, 2023 15:26:43.240 [547643433184] DEBUG - Completed after connection close: [192.168.1.31:63205] -3 GET /:/websockets/notifications?filters=log (8 live) #443 TLS GZIP 138478ms 21929 bytes
Jul 12, 2023 15:26:43.277 [547538055392] DEBUG - Request: [192.168.1.31:63238 (Subnet)] GET /:/prefs (10 live) #4ef TLS GZIP Signed-in Token (mdreed72) (Chrome)
Jul 12, 2023 15:26:43.280 [547593269472] DEBUG - Request: [192.168.1.31:63239 (Subnet)] GET /accounts/1 (10 live) #565 TLS GZIP Signed-in Token (mdreed72) (Chrome)
Jul 12, 2023 15:26:43.285 [547576361184] DEBUG - Request: [192.168.1.31:63240 (Subnet)] GET /myplex/account (10 live) #564 TLS GZIP Signed-in Token (mdreed72) (Chrome)
Jul 12, 2023 15:26:43.299 [547641323744] DEBUG - Completed: [192.168.1.31:63239] 200 GET /accounts/1 (10 live) #565 TLS GZIP 22ms 683 bytes (pipelined: 1)
Jul 12, 2023 15:26:43.299 [547641323744] DEBUG - Completed: [192.168.1.31:63240] 200 GET /myplex/account (10 live) #564 TLS GZIP 14ms 3965 bytes (pipelined: 1)
Jul 12, 2023 15:26:43.311 [547641323744] DEBUG - Completed: [192.168.1.31:63238] 200 GET /:/prefs (10 live) #4ef TLS GZIP 34ms 8863 bytes (pipelined: 1)
Jul 12, 2023 15:26:45.951 [547593269472] DEBUG - Request: [192.168.1.31:63244 (Subnet)] GET /diagnostics/logs (11 live) #566 TLS GZIP Signed-in Token (mdreed72) (Chrome)
Jul 12, 2023 15:26:45.951 [547593269472] DEBUG - [Req#566] Diagnostics: Building logfile zip
What is it doing now?
Lastly, Regarding my tool, it knows the all the syno & docker structures (when run from inside the docker container), so that should still be good for you …
Please advise.
