Require a little help installing Plex Connect
Hello, sorry to be a bother but I've been struggling to get plex connect to work.
Whenever I click on the Plexconnect.py file to start it all, it just flashes up and then vanishes.
I have already read all the other topics about using the cmd code, but its just not working.
cd "C:\Program Files (x86)\PlexConnect-master"
Plexconnect.py
Screenshot -
[spoiler]IFx4QGT.png?1[/spoiler]
log would be fine...
My assumption: Wrong Python version (like 3 or so...).
Currently running Python 3.4
Python 3.x is not supported, uninstall and reinstall the latest 2.x version
I am having the same issue but am running 2.7.8.
Where is your logs? It won't be the same issue if your on that version of Python as that error is due to incompatibility with v 3 Python.
Best to follow the pinned thread READ BEFORE POSTING thread specifically the section on how to report a problem. (Also don't hijack a thread start your own, that way you get answers for you not mixed with answers for someone else)
I'll make a new post following the template in just a couple minutes. Thank you.
