Currently, the plex app does not support the resizing of its window via Android XR. This means that the window in the 3D environment is always the same size and doesn’t work well while multitasking with other apps. You can see an example circled in blue in the image below. By pinching the corner, you are able to resize the window. Plex currently doesn’t have this feature.
Related topics
| Topic | Replies | Views | Activity | |
| Allow window resizing on PCs for more of a tablet sized UI [ignore, was a bug] | 4 | 94 | June 4, 2021 | |
| [Feature Request] Support for Multi-Window on Android 7.x | 0 | 77 | November 12, 2016 | |
| Visualizzazione APP a tutto schermo del TV (troppo grande) | 0 | 76 | June 3, 2021 | |
| Plex is scaled incorrectly when used with an android desktop (samsung dex, lenovo, etc) | 13 | 354 | August 6, 2026 | |
| Using Plex Windows on multiple monitors mixed 4K & 1080 - not good | 0 | 69 | January 2, 2024 |
