As above.
The tiny UI is the only thing stopping me from using it on my PC. I’m not asking for a complete rework but just to show more artists on the grid, more albums in the list etc like it would appear on a tablet.
Plex web just isn’t a good enough client for music for me as it lacks gapless playback, ReplayGain and other important features.
Not sure what exactly you’re missing… if you’re using Plexamp on your desktop you should already be able to see the adaptive layout when resizing your window (for both the now playing window as well as the library views).
Edit: + the Large grid size option under the Appearance settings.
Oh? It doesn’t let me resize. The resize arrows appear at the edge of the window and I can click them, but they won’t actually move anywhere… hmm
I am using Linux which is probably a factor.
What version of Plexamp do you have installed and on what distribution/version of Linux are you running it?
Edit: do you experience the same resizing behavior on all edges and corners?
If I remember correctly, window behavior can be limited on some UIs – even if the cursor icon is changing to a resize symbol, the OS UI might not support that in every case. That being said… it’s been some time since I’ve used Linux on a desktop
Aha! Updating to 3.4.7 has fixed it. Never mind then.
E: I was on 3.4.4.
