@JuiceWSA said:
VLC is designed to play any crap you throw at it.
Evidently, so is the Mac/iOS app “InFuse”… But somehow both of those know to remove the vertical black bars and then unstretch the rest of the image. How, I don’t know.
The converter I use to go from MKV to the easier-to-use .mp4 allowed me to convert and stretch it back to the aspect ration that makes it look normal (and looks 16:9).
Plex is more - ‘refined’ - you have to encode a higher level of crap.
I thought that Plex used VLC libraries to play vids. Ah well…
Until I can see a Media Info Report of the original source file I can’t tell you how to encode it and unless you’re using Handbrake - you’re on your own. I don’t know how what ever you’re using works or what it’s doing to your files.
I said… it’s an MKV downloaded via an NZB. I didn’t do anything “to” it. The only app I have to play MKVs is VLC and VLC somehow knows how to play it to look right. So I converted it as-is to MP4. THEN I can see how Plex shows it.
I’ll also need to see the file’s info after what ever you’re using is done with it.
MediaInfo
You asked:
General
Unique ID : 174348751585264935390696662000156435004 (0x832A591FFECB1AA937973EACF48E623C)
Complete name : The Doctor Blake Mysteries S05E01 A Lethal Combination.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 1.82 GiB
Duration : 58mn 31s
Overall bit rate : 4 460 Kbps
Encoded date : UTC 2017-09-18 20:11:35
Writing application : mkvmerge v15.0.0 (‘Duel with the Devil’) 64-bit
Writing library : libebml v1.3.5 + libmatroska v1.4.5
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L3.1
Format settings : 2 Ref Frames
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 58mn 31s
Bit rate : 4 074 Kbps
Width : 960 pixels
Height : 718 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.236
Stream size : 1.67 GiB (91%)
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 58mn 31s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Frame rate : 31.250 fps (1536 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 161 MiB (9%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 57mn 15s
Bit rate : 74 bps
Count of elements : 942
Stream size : 31.1 KiB (0%)
Language : English
Default : No
Forced : No
