Resolved
I have had Plex hardware transcoding working for a long time and this AM I installed a GPU to pass through to a VM. I have lost hardware transcoding on Plex. The dropdown box only shows auto so I cannot pick it from the Plex settings. I am on Unraid using the official Plex docker. I understand that I may need to update the Plex preferences XML file. The problem is I have no idea what to put in there, as I have found the following on the Plex forums. "
User plex is added to the group of the first card found
To manually override the device used, specify HardwareDevicePath=“/dev/xxxxxxxxx” in Preferences.xml (while Plex is stopped)
udev should be adding both devices to the same group (render)"
I am unsure what to replace the XXXX with or where to find out.
Thanks for any help you can provide.
Realized that the bios shut down the igpu when gpu was instaslled. After enabling everything is A OK
