Just saw your post, sorry for the delay. will test it out shortly and let you know if its working.
Seems to be working. Only tried one title. Will keep at it when I get new titles and see how it goes.
Tried to install this but it doesn’t even show up with the other agents, is it broken again?
Plex recognizes the bundle for me, but I removed the ‘-master’ I don’t know if that mattered.
@kjcrowley said:
@Naesstrom said:
Tried to install this but it doesn’t even show up with the other agents, is it broken again?Plex recognizes the bundle for me, but I removed the ‘-master’ I don’t know if that mattered.
Same here works just fine now. Nice work
Does this still work? I seems to only pull the cover for me, any way to have it pull the cast also?
I have been doing my own updates to this plug-in… what I have works, including pulling the “Categories”… I am trying to get it to import the preview/trailer for the movie as well, but can’t ID the correct metadata elements to use… see the attached file.
If anyone has thoughts on how to get the previewURL loaded into the metadata, let me know.
I’ve made some more code updates to this metadata agent, and will upload when I have a chance… I need to update the comments to make it more explanatory for those that are still learning…
I am attaching my latest updates here, with inline comments
Note: This is still a work in progress, as I find that ADE updates their page formats from time to time, and I find new things that need to be accounted for in the script…
thank you for continuing to update this plugin
This is working PERFECTLY. Thank you cepelkey! Definitely think about putting your fork up on Github.
Keep up the good work.
Just downloaded and trying this today. The only thing not working for me is the actor images. It’s only showing initials. Any ideas?
